RF ID Reader Help
ritchie
RF ID Reader Help
PostPosted: Sat Oct 25, 2003 9:14 pm     Reply with quote
The code for writing to FRAM does work coz I already test it for a fixed systhetic data to write and it did...
as for the LCD display... I just diplay what the serial gets? dis is not a duplicate... my concern is the duplicate entry in the memory?
Need Help on this...
This my alpha version of my code.. I need help on how I can eliminate the duplicate entry in my memory storage...
Thnx
#include <18F452.h> // Target PIC Microcontroller IC
#fuses HS,NOPROTECT,NOWDT // PIC MCU Configuration
#use delay(clock=20000000) // 20MHz Crystal clock speed
#include <LCD.C> // LCD routines are here
#include <stdlib.h> // Standard library routines
int1 glRfMemWriteFlag = 0; // Memory write flag bit
int1 glRfIdBufferAvailable = 0; // RF Rx buffer is available
int1 glRfIdBufferDataReady = 0; // RF data receive and ready
int8 seconds ; // 00 - 59 seconds
int8 minutes ; // 00 - 59 minutes
int8 hours ; // 00 - 23 hours, military format
int8 mthdays ; // 01 - 31 days in a month
int8 months ; // 01 - 12 months, 1-JAN, ..., 12-DEC
int8 years ; // 00 - 99 2-digit year within a century
int8 y2kyrs ; // 20 - 99 Y2K year or century
int8 dummy ; // scratch pad or dummy variable 1
int8 i ; // scratch pad or dummy variable 2
char gaRawRFCode[12]; // RF raw code data
#define RF_SIZE 12 // RF Rx buffer size for RS-232 receive
byte rfbuffer[RF_SIZE]; // RF receive serial data buffer
byte rf_in = 0; // Rx data in index
byte rf_out = 0; // Rx data out index
// I2C Configuration
#define FRAM_SDA PIN_C4 // i2c data
#define FRAM_SCL PIN_C3 // i2c clock
#define FRAM_WP PIN_C5 // write protect pin
// define I2C read/write address
#define FRAM_WR_ADDR 0xA0 // initial F-RAM write address at 1st chip
#define FRAM_RD_ADDR 0xA1 // initial F-RAM read address at 1st chip
//#define FRAM_SIZE 32768 // for FM24C256
#define FRAM_SIZE 262144 // max bytes for 8chips of FM24C256
#define DATA_SIZE 32 // data size for one(1) swipe transaction
char gcMemBuffer[DATA_SIZE]; // dummy memory buffer before storage;
unsigned int32 guStrtAddr = 32; // FM24C256 start address pointer
unsigned int32 guEndAddr = 32; // FM24C256 end address pointer
unsigned int16 guLogCount = 0; // Log Counter (how many swipe?)
unsigned int1 guFramCont = 0; // FRAM content flag bit
// Configuration Registers for I2C
unsigned char SSPADD;
#locate SSPADD=0x0FC8
unsigned char SSPBUF;
#locate SSPBUF=0x0FC9
unsigned char SSPCON1;
#locate SSPCON1=0x0FC6
struct {
unsigned char SSPM0:1;
unsigned char SSPM1:1;
unsigned char SSPM2:1;
unsigned char SSPM3:1;
unsigned char CKP:1;
unsigned char SSPEN:1;
unsigned char SSPOV:1;
unsigned char WCOL:1;
} SSPCON1bits ;
#locate SSPCON1bits=0x0FC6
unsigned char SSPCON2;
#locate SSPCON2=0x0FC5
struct {
unsigned char SEN:1;
unsigned char RSEN:1;
unsigned char PEN:1;
unsigned char RCEN:1;
unsigned char ACKEN:1;
unsigned char ACKDT:1;
unsigned char ACKSTAT:1;
unsigned char GCEN:1;
} SSPCON2bits ;
#locate SSPCON2bits=0x0FC5
unsigned char SSPSTAT;
#locate SSPSTAT=0x0FC7
struct {
unsigned char BF:1;
unsigned char UA:1;
unsigned char R_W:1;
unsigned char S:1;
unsigned char P:1;
unsigned char D_A:1;
unsigned char CKE:1;
unsigned char SMP:1;
} SSPSTATbits ;
#locate SSPSTATbits=0x0FC7
unsigned char PIR2;
#locate PIR2=0x0FA1
struct {
unsigned char CCP2IF:1;
unsigned char TMR3IF:1;
unsigned char LVDIF:1;
unsigned char BCLIF:1;
unsigned char EEIF:1;
} PIR2bits ;
#locate PIR2bits=0x0FA1
// Useful defines for writing to the I2C bus
#define I2C_IDLE() while ((SSPCON2 & 0x1F) || (SSPSTATbits.R_W))
#define I2C_START() \
SSPCON2bits.SEN = 1; \
while (SSPCON2bits.SEN) \
#asm nop #endasm \
#define I2C_RESTART() \
SSPCON2bits.RSEN = 1; \
while (SSPCON2bits.RSEN) \
#asm nop #endasm \
#define I2C_STOP() \
SSPCON2bits.PEN = 1; \
while (SSPCON2bits.PEN) \
#asm nop #endasm \
#define I2C_WRITE(x) \
SSPBUF = (x); \
while (SSPSTATbits.BF) \
#asm nop #endasm \
I2C_IDLE()
#define I2C_READ(x) \
SSPCON2bits.RCEN = 1; \
while (SSPCON2bits.RCEN) \
#asm nop #endasm \
SSPCON2bits.ACKDT = (x); \
SSPCON2bits.ACKEN = 1; \
while (SSPCON2bits.ACKEN) \
#asm nop #endasm \
static BOOLEAN I2C_Device_Ready(unsigned int8 uID);
#int_rda
void RFid_isr() // RF ID Reader interrupt routines
if(glRfIdBufferAvailable)
rfbuffer[rf_in]=getc();
rf_in++;
if(rf_in==RF_SIZE)
glRfIdBufferAvailable = 0; // buffer is full
glRfIdBufferDataReady = 1; // RF data is available
glRfMemWriteFlag = 1; // set flag for memory write
rf_in = 0; // restart pointer to zero
else getch();
void fram_init() // initialize FRAM
output_float(FRAM_SCL); // set clock to input
output_float(FRAM_SDA); // set data to input
void fill_memory_buffer() // fill memory buffer before storage
char aTempBuffer[21];
char cMode='M'; // log mode is set to manual
int16 iAddress = 0xABBA; // initial device address
for (i=1; i<10; i++)
{ // fill gcMemBuffer with decoded barcode data
gcMemBuffer[i-1] = gaRawRFCode[i];
// fill aTemp_Buffer with data
sprintf(aTempBuffer,"%02u:%02u%02u-%02u-%02u%02u%C%04LX",
hours,minutes,mthdays,months,y2kyrs,years,cMode,iAddress);
for (i=9; i<30; i++)
{ // fill gcMemBuffer with data
gcMemBuffer[i] = aTempBuffer[i-9];
// set the last two array content to NULL
gcMemBuffer[30] = 0;
gcMemBuffer[31] = 0;
do
// Important to clear these bits before we attempt to write
PIR2bits.BCLIF = 0;
SSPCON1bits.WCOL = 0;
I2C_IDLE(); // ensure module is idle
I2C_START();
} while (PIR2bits.BCLIF);
I2C_WRITE(uID); // send memID
if (!SSPCON2bits.ACKSTAT) // test for ACK condition, if received
return (TRUE);
return (FALSE); // no ACK
// Write one block of data to the FM24C256 chip
void write_fram_block(
unsigned int32 uAddress, // FM24C256 address to write data
unsigned int8 Block, // block length or one page write
unsigned int8 *gcMemBuffer) // pointer to gcMemBuffer to get data
unsigned int8 uControl; // FM24C256 chipselect
unsigned int8 uI;
// chipselect for specific FM24C256 to write
uControl = (FRAM_WR_ADDR | make8(uAddress<<2,2)) & 0xFE;
output_low(FRAM_WP); // set write protect low
while (!I2C_Device_Ready(uControl));
I2C_WRITE((make8(uAddress,1)) & 0x7F); // send MSB of mem address
I2C_WRITE(make8(uAddress,0)); // send LSB of mem address
for (uI=0; uI<Block; uI++)
I2C_WRITE(*gcMemBuffer++); // send data to FM24C256
I2C_STOP();
output_high(FRAM_WP); // set write protect high
void read_fram_block(
unsigned int8 *gcReadMemBf)
I2C_RESTART();
I2C_WRITE(uControl | 0x01); // set address for read
while (Block > 1)
I2C_READ(0);
*gcReadMemBf = SSPBUF;
gcReadMemBf++;
Block--;
I2C_READ(1);
I2C_STOP();
// Write one byte to the Ramtron FM24C256 chip
void write_fram_Byte(
unsigned int32 uAddress, // FRAM address to write data
unsigned int8 uData) // byte written to FRAM
I2C_WRITE(uData); // send data
I2C_STOP();
// Read one byte from the Ramtron FM24C256 chip
unsigned int8 read_fram_byte(
unsigned int32 uAddress) // FM24C256 address to write data
I2C_RESTART();
I2C_READ(1);
I2C_STOP();
return (SSPBUF); // return with data
// Configure the MSSP as an I2C Port for PIC18F452
// Relevant port pins configured as inputs
void ConfigureI2C(void)
SSPCON1bits.SSPEN = 1; // bit_set(SSPCON,SSPEN); // Enable I2C mode
SSPCON1bits.SSPM3 = 1; // bit_set(SSPCON,SSPM3); // Setup I2C
SSPCON1bits.SSPM2 = 0; // bit_clear(SSPCON,SSPM2);
SSPCON1bits.SSPM1 = 0; // bit_clear(SSPCON,SSPM1);
SSPCON1bits.SSPM0 = 0; // bit_clear(SSPCON,SSPM0);
SSPCON2 = 0;
SSPSTATbits.SMP = 0; // bit_clear(SSPSTAT,SMP);
SSPSTATbits.CKE = 0; // bit_clear(SSPSTAT,CKE); // Set I2C Levels
// Set I2C Speed. The formula is:
// SSPADD value = (Fosc/(i2c clock speed * 4)) -1
// Examples:
// SSPADD values for an Fosc of 8 MHz:
// *** NOTE: If you run your PIC at a different Fosc, then you
// *** you need to calculate new values.
// For an i2c clock of 100 KHz, SSPADD = 19
// For an i2c clock of 400 KHz, SSPADD = 4
// For an i2c clock of 1 MHz, SSPADD = 1
SSPADD = 4; // 1 MHz i2c clock at 20MHz oscillator
SSPSTATbits.SMP = 1; // bit_set(SSPSTAT,SMP);
// Disable slew rate control
// for 1 MHz operation ONLY
// *** NOTE: Based on my oscilloscope readings, the i2c clock
// *** speed seems to run a little slower than what the formula says.
// *** For example, "400 KHz" is really 370 KHz or so.
// *** "1 MHz" is really running slightly less than that speed.
void write_data_to_memory()
unsigned int32 uLoc;
// get the start address
//guStrtAddr = make32(read_program_eeprom(0x7FE0),
// read_program_eeprom(0x7FE1));
// get the end address
//guEndAddr = make32(read_program_eeprom(0x7FE2),
// read_program_eeprom(0x7FE3));
if (guStrtAddr == guEndAddr)
uLoc = guStrtAddr; // set uLoc to guStrtAddr
if (guStrtAddr != guEndAddr)
uloc=guEndAddr; // set uLoc to guEndAddr
if (guEndAddr == FRAM_SIZE)
uLoc = 32; // memory overflow... max size reach
// reset end pointer to location 32 of
// chip address A0
// write data to FM24C256
write_fram_block(uLoc,DATA_SIZE,gcMemBuffer);
guEndAddr = uLoc + DATA_SIZE; // increment guEndAddr by 32bytes
void nulrfbuffer() { // put a NULL
for (i=0;i<RF_SIZE;i++) // to entire buffer size
rfbuffer[i]=0 ; // of rfbuffer
rf_in=0; // restart pointer to zero
void nulrfrawcode() {
gaRawRFCode[i]=0 ; // put a NULL to gaRawRFCode array
void clear_lcd_display()
lcd_gotoxy(1,2);
printf(lcd_putc," ");
void init_chip() { // Initialize the MCU Chip
lcd_init(); // LCD should be initialized first
fram_init(); // Initialize ports for I2C
ConfigureI2C(); // Configure I2C bus
read_fram_hdr(); // read FRAM header (e.g. start, end, log count)
seconds = 59 ; // 00 - 59 seconds
minutes = 1 ; // 00 - 59 minutes
hours = 18 ; // 00 - 23 hours, military format
mthdays = 3 ; // 01 - 31 days in a month
months = 10 ; // 01 - 12 months, 1-JAN, ..., 12-DEC
years = 03 ; // 00 - 99 2-digit year within a century
y2kyrs = 20 ; // 20 - 99 Y2K year or century
enable_interrupts(int_rda); // Rx serial receive interrupt
enable_interrupts(GLOBAL); // Global interrupt
main()
nulrfbuffer(); // put NULL at RF buffer array
nulrfrawcode(); // put NULL at RF raw code array
init_chip(); // Initialize the MCU Chip
lcd_gotoxy(1,1);
printf(lcd_putc,"HTI-200R");
glRfIdBufferAvailable = 1; // Rx buffer is empty
glRfIdBufferDataReady = 0; // RF data buffer is empty
glRfMemWriteFlag = 0; // memory write disabled
while (TRUE)
if (glRfIdBufferDataReady)
//strncpy(gaRawRFCode,buffer,12);
strcpy(gaRawRFCode,rfbuffer);
for(dummy=0; dummy<RF_SIZE; dummy++)
//lcd_putc(Buffer[uCount]);
//gaRawRFCode[uCount]=Buffer[uCount];
lcd_putc(gaRawRFCode[dummy]);
if(glRfMemWriteFlag)
//for (uIndex=0; uIndex<DATA_SIZE; uIndex++)
fill_memory_buffer();
write_data_to_memory();
//write_fram_byte(uIndex,rfBuffer[uIndex]);
Humberto
PostPosted: Sun Oct 26, 2003 9:04 am     Reply with quote
This is the same thread that Ttelmah answer you with several tips and a very good analisys. It would be nice to know if you implemented those suggestions.
Reading your code I see in your #INT_RDA that the buffer pointer [rf_in] in not initialized to start storing the first char you expect (of your packet), instead is inialized to start storing the first char that arrive.
#int_rda
rf_in++;
if(rf_in==RF_SIZE)
else getch();
I will try this:
#int_rda
int char_rcved;
     char_rcved=getc();
     if(char_rcved == PacketLeader)  // the first char you expect
         rf_in=0;
     rfbuffer[rf_in]= char_rcved;
     rf_in++;
     if(rf_in==RF_SIZE)
   else getch();
Hope this help you,
Humberto
