Markdem
quick math question |
Posted: Sat Feb 25, 2006 8:01 pm |
Hi All, i need to the the following sum in C.
CO2 = 3 * KH * 10( 7-pH )
To do this i have tried:
currentph = 7.8;
currentkh = 4;
phsum = 7 - currentph;
currentco2 = 3 * currentkh * pow(10,phsum);
but it will always give back strange numbers, eg number that have nothing in common with what i am doing. Can sombody help??
Thanks, Mark |
kender
Posted: Sat Feb 25, 2006 8:30 pm |
I don't see the problem with the code you have posted, but the problem might exist elsewhere.
Please post also:
- Declarations of variables
- Your erroneous results
- Inputs that produce these erroneous results
- type of PIC you are writing for |
jecottrell
Posted: Sat Feb 25, 2006 8:51 pm |
Try some of these additions to your code to circumvent the possibility of CCS 'features'.
float phsum = 0.0;
float currentph = 7.8;
float currentkh = 4.0;
phsum = 7.0 - currentph;
printf("currentC02 = %7.2f\n\r", currentco2 );
I can't guarantee my approach is the correct one, but I bet this will probably spark a lot of good posts from the pros on what does and does not work with mixing of data types and the printf problems inherent in some of the later versions of the CCS compiler. So, with that said, your problem is most likely caused by either data types or printf formats, and without a code snippet that clarifies anything having to do with those problems, you probably won't get a very complete answer.
Good luck,
John |
Markdem
Posted: Sun Feb 26, 2006 2:30 am |
Thanks for the replys guys.
I have now found out that if i do the following, it all works fine
currentco2 = 3 * currentkh * pow(10.0,-1.0);
but as soon as i change it the the following, all i get as a output is a big fat 0
currentco2 = 3 * currentkh * pow(10.0,phsum);
Here is the whole code.
#include <16F88.h>
#FUSES NOWDT, INTRC_IO, NOPUT, NOMCLR, NOBROWNOUT, NOLVP, NODEBUG, NOPROTECT, NOFCMEN, NOIESO, NOWDT
#use rs232(baud=2400,parity=N,bits=8,xmit=PIN_B5,rcv=PIN_B2)
#include<math.h>
#include<ds1820hood.c>
#include<ds1820water.c>
int serialreq, i;
int currentph;
long readadc, currentwatertemp, currenthoodtemp, currentco2i;
float mathtemp, currentkh, currentco2, phsum;
void tempwork()
currenthoodtemp = onewire_ds1822_read_temp_c_lite_hood();
currentwatertemp = onewire_ds1822_read_temp_c_lite_water();
void phwork()
// readadc = Read_ADC();
// delay_ms(200);
// mathtemp = (readadc / 21.7659) * 100;
// currentph = (9900 - mathtemp) / 100;
currentph = 8;
currentco2i = currentco2 * 10;
void main ()
setup_port_a(ALL_ANALOG); //setup adc
set_adc_channel(2);
enable_interrupts(INT_RDA);
while (TRUE)
output_low(pin_b4);
tempwork();
phwork();
output_high(pin_b4);
delay_ms(2500);
Thanks very much.
Mark |
kender
Posted: Sun Feb 26, 2006 2:46 am |
In your complete code I could not find a place where you initialize currentkh variable. Try this:
currentph = 8.0; // force to float
currentkh = 1.0; // or whatever
currentco2 = 3.0 * currentkh * pow(10.0,phsum);
Also I couldn't find your calls to printf(). Do you stop the execution at the break point to view the variables? |
Markdem
Posted: Sun Feb 26, 2006 3:19 am |
Hi kender, thanks for you help.
You could not find when i define currentkh because i am no thinking very well today.
Lets try again
#include <16F88.h>
#include<math.h>
int serialreq, i;
int currentph;
void tempwork()
void phwork()
// delay_ms(200);
phsum = 7.0 - 8.0;
printf("co2 =%u",currentco2i);
void main ()
set_adc_channel(2);
readadc = 607;
currentph = 8;
currentkh = 4
while (TRUE)
output_low(pin_b4);
tempwork();
phwork();
delay_ms(3000);
Thanks again, Mark |
