colin
interrupt - external(pin b0) |
Posted: Tue Sep 09, 2003 5:32 pm |
Hi all,
would you guys pls show me how to write an interrupt to trigger a switch(connected to Pin B0) from high to low?
I followed the example (ex_wake.c), however, it worked once, and didn't work after that <- weird, huh?! I'm tring to implement a sleep mode (try put it sleep and weak it up by a switch).
I have a timer interrupt and it works fine. when I have a delay_ms(1000) function in #INT_EXT, void ext_isr(), it also delay my timer2?! I also tried put a printf function and a output_high(R1) function in ext_isr() but it showed nothing. It seems the ext_isr() function didn't call at all. I cehcked the INTCON register, bit 7 should be 1, but it showed 0. when I took out the delay function in ext_isr(), everything became normal.
I'm using Mplab 6.3, PCM 3.176, 16F877, PICDEM 2 Plus, ICD 2
Here's my code (took out unnecessary part):
#include <test_sleep_mp.h>
#include <timer2.c>
long counter;
sleep_mode=FALSE;
ext_int_edge(H_TO_L);
enable_interrupts(INT_EXT);
//initialize function
init_timer2();
enable_interrupts(global);
if(sleep_mode)
sleep();
output_high(PIN_B3);
output_low(PIN_B3);
printf("while");
timer source file
#include <timer2.h>
void init_timer2(void) {
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
//setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_16,42,15);
//interrupt function - count for 1 sec
#int_TIMER2
void TIMER2_isr(void) {
if(++ten_msec_count>=100){
ten_msec_count = 0;
output_high(PIN_B2);
else if(++ten_msec_count<=50){
output_low(PIN_B2);
#INT_EXT
void ext_isr() {
static short button_pressed=FALSE;
if(!button_pressed) // if button action and was not pressed
button_pressed=TRUE; // the button is now down
//sleep_mode=TRUE; // activate sleep
printf("The processor is now sleeping.\r\n");
ext_int_edge(L_TO_H); // change so interrupts on release
else // if button action and was pressed
button_pressed=FALSE; // the button is now up
sleep_mode=FALSE; // reset sleep flag
ext_int_edge(H_TO_L); // change so interrupts on press
if(!input(PIN_B0)) // keep button action sychronized wth button flag
printf("EXT_INT\n\r");
delay_ms(100); // debounce button
output_high(PIN_B1); //** commented out upper park and test if this function called by interrupt
Posted: Tue Sep 09, 2003 6:01 pm |
Here's an example of how you can use INT_EXT with a push-button
switch. I don't have time to integrate it into your Sleep program.
But hopefully it will give you some hints.
#include "16F877.h"
#fuses HS, NOWDT, NOPROTECT, PUT, BROWNOUT, NOLVP
#use Delay(Clock=8000000)
#zero_ram
// GLOBALS
char got_interrupt;
char interrupt_count;
#bit INTF_BIT = 0x0B.1
// FUNCTION PROTOTYPES
#int_ext
void int_ext_isr(void);
// Make pin B0 into an input.
output_float(PIN_B0);
// Enable pullups on all port B pins.
port_b_pullups(TRUE);
// Wait for them to pull up.
delay_us(10);
// Initialize the variables used by the interrupt routine,
// before enabling interrupts.
interrupt_count = 0;
got_interrupt = FALSE;
// Since we have port B pullups enabled, the normal state
// of Pin B0 is a high level. Let's set up the external
// interrupt to occur whenever we get a change from
// a high to a low level.
// We will connect a Normally-open push-button switch to Pin B0.
// The "common" pin of the switch goes to Ground.
// When we press the button, Pin B0 will go to logic low level.
// Make sure the external interrupt flag bit is cleared
// before enabling external interrupts.
INTF_BIT = 0;
// Wait in this loop. Check the got_interrupt flag to see
// if an interrupt occurred. If so, display the count.
// Then clear the flag, wait 50 ms to avoid any "bounce"
// (multiple interrupts) when we press the pushbutton switch,
// which puts Ground on pin B0. Then re-enable interrupts.
if(got_interrupt == TRUE)
printf("%d\n\r", interrupt_count);
// Clear the global flag which was set in the interrupt routine.
// Wait for debounce period. This allows time for the switch contacts
// to quit bouncing.
delay_ms(50);
// Clear any interrupt which might have occurred during the debounce period.
INTF_BIT = 0;
// Then re-enable interrupts.
#int_ext
got_interrupt = TRUE;
interrupt_count++;
disable_interrupts(INT_EXT);
colin
thanks |
Posted: Tue Sep 09, 2003 6:10 pm |
PCM programmer,
thanks for your advice b4 taking off.
thanks again.
Hope your program helps. |
sliders_alpha
Posted: Sun Apr 19, 2009 11:57 am |
i was looking or that, thanks
#bit INTF_BIT = 0x0B.1 |
and doing that after each interrupt :
is still required those day (CCS 4.057)? _________________ yup, i know, i don't speak english very well
CCS V4.057 |
Posted: Sun Apr 19, 2009 12:16 pm |
The compiler does not clear a peripheral interrupt flag when you call
the enable_interrupt() function. This applies to old versions of the
compiler and to new versions.
For example, these lines do not clear the INTF flag:
Quote: | enable_interrupts(INT_EXT);
enable_interrupts(GLOBAL); |
The modern compiler now has a function to clear the flag,
so you can call it like this:
