Sherpa Doug Guest
printf question |
Posted: Wed Nov 27, 2002 3:34 pm |
What is the difference between:
fprintf(fish,"$04lu\n\r",Temp);
and
fprintf(fish,"$4lu\n\r",Temp);
The manual says the 4 specifies how many characters are to be outputted, or 04 to indicate leading zeros.... So if I use just 4 do I get leading spaces? how does it generate 4 characters?
___________________________
Original Post ID: 9527 |
Re: printf question |
Posted: Wed Nov 27, 2002 3:54 pm |
:=What is the difference between:
:=fprintf(fish,"$04lu\n\r",Temp);
:=and
:=fprintf(fish,"$4lu\n\r",Temp);
:=The manual says the 4 specifies how many characters are to be outputted, or 04 to indicate leading zeros.... So if I use just 4 do I get leading spaces? how does it generate 4 characters?
The program given below, generated this output:
<PRE>
0123
123
</PRE>
The first line has a leading 0, and the 2nd line has a leading
space.
#include "c:\program files\picc\devices\16F877.h"
#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT, NOLVP
#use Delay(clock=8000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, STREAM=Fish)
main()
long Temp;
Temp = 123;
fprintf(fish,"\%04lu\n\r",Temp);
fprintf(fish,"\%4lu\n\r",Temp);
Original Post ID: 9529 |
Ed Arnold Guest
Posted: Wed Nov 27, 2002 3:56 pm |
:=and
I have used this on many projects and you are correct "\%04lu" will give you leading zeros and "\%4lu" will in fact give leading spaces, at least on an LCD screen. Sort of like right justifying the output. I have not tried this for outputting on a serial stream. By the way, I think you meant to use '\%' signs in your code instead of '$'. Hope this helps.
Ed Arnold
Original Post ID: 9530 |
david smith Guest
Re: printf formatting |
Posted: Wed Nov 27, 2002 5:38 pm |
Note also, at least with this compiler,
\%04Lu is interpreted the same, and the L is not misread as 1.
Also, before you try, the leading zero doesn't work for floats.
Original Post ID: 9538 |
Phil G Guest
Posted: Wed Nov 27, 2002 8:22 pm |
:=:=What is the difference between:
:=:=fprintf(fish,"$04lu\n\r",Temp);
:=:=and
:=:=fprintf(fish,"$4lu\n\r",Temp);
:=:=The manual says the 4 specifies how many characters are to be outputted, or 04 to indicate leading zeros.... So if I use just 4 do I get leading spaces? how does it generate 4 characters?
:=The program given below, generated this output:
:=<PRE>
:=0123
:= 123
:=</PRE>
:=The first line has a leading 0, and the 2nd line has a leading
:=space.
:=#include "c:\program files\picc\devices\16F877.h"
:=#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT, NOLVP
:=#use Delay(clock=8000000)
:=#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, STREAM=Fish)
:=main()
:=long Temp;
:=Temp = 123;
:=fprintf(fish,"\%04lu\n\r",Temp);
:=fprintf(fish,"\%4lu\n\r",Temp);
:=while(1);
What is the output if Temp = 12345 ?
Original Post ID: 9545 |
Tomi Guest
Posted: Thu Nov 28, 2002 1:54 am |
Not sure about CCS C but the original C printf definition says that your format expresssion must long enough to fit the number. So in a legal C the output for 12345 is "12345" regardless of the "\%04lu" format (the printf could not truncate the number). And maybe this is the reason why we have problems with printing floats.
:=:=:=What is the difference between:
:=:=:=fprintf(fish,"$04lu\n\r",Temp);
:=:=:=and
:=:=:=fprintf(fish,"$4lu\n\r",Temp);
:=:=:=The manual says the 4 specifies how many characters are to be outputted, or 04 to indicate leading zeros.... So if I use just 4 do I get leading spaces? how does it generate 4 characters?
:=:=The program given below, generated this output:
:=:=<PRE>
:=:=0123
:=:= 123
:=:=</PRE>
:=:=The first line has a leading 0, and the 2nd line has a leading
:=:=space.
:=:=#include "c:\program files\picc\devices\16F877.h"
:=:=#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT, NOLVP
:=:=#use Delay(clock=8000000)
:=:=#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, STREAM=Fish)
:=:=main()
:=:=long Temp;
:=:=Temp = 123;
:=:=fprintf(fish,"\%04lu\n\r",Temp);
:=:=fprintf(fish,"\%4lu\n\r",Temp);
:=:=while(1);
:=What is the output if Temp = 12345 ?
Original Post ID: 9557 |
