Kamal Guest
| Trying to read Port B and Write to Port D |
Posted: Tue Nov 26, 2002 1:41 pm |
I am using PIC16F877 for my project and I am simply trying to read 8-bit data from port B. I have a dip switch connected to the pins corresponding to Port B, which provides the 8bit data.
Then I assinged these 8bits to port D. I have eight LED's connected to the pins corresponding to Port D.
int value=0;
int value_ascii=0;
// init_mem();
value = input_b();//is it correct to read port B this way?
value_ascii = (value-48);
printf("\%d ", value_ascii);
output_d(value); //is it correct to write to port D?
First of all, I am getting "Funtion not defined error" referring to my input_b(); line
Is there some header file or anything like such that i should be including in order for the complier to recognize input_b();
Is my methodology correct? any suggestions will be helpful
Thank you
kamal
___________________________
Original Post ID: 9457 |
| Re: Trying to read Port B and Write to Port D |
Posted: Tue Nov 26, 2002 2:09 pm |
:=I am using PIC16F877 for my project and I am simply trying to read 8-bit data from port B. I have a dip switch connected to the pins corresponding to Port B, which provides the 8bit data.
I assume the Dip switches are connected to ground (or to
ground through a 1K resistor). Do you have pull-up resistors
on the Port B pins ? If not, you should enable the Port B
pullups with the CCS function "port_b_pullups(TRUE)".
:=Then I assinged these 8bits to port D. I have eight LED's connected to the pins corresponding to Port D.
Do you have resistors in series with each LED ?
You can use 220 ohms.
:=void main(void)
:= int value=0;
:= int value_ascii=0;
:=// init_mem();
:= delay_ms(1000);
:= while(1)
:= value = input_b();//is it correct to read port B this way?
:= value_ascii = (value-48);
In the line above, you're removing ASCII bias by subtracting
48 from the value (Assuming that "value" is in ASCII format).
So why do you call the result variable "value_ascii" ?
I would call it "value_binary" instead.
:= printf("\%d ", value_ascii);
:= output_d(value); //is it correct to write to port D?
:=First of all, I am getting "Funtion not defined error" referring to my input_b(); line
What version of the compiler do you have ? It compiles OK
with PCM vs. 3.110.
:=Is there some header file or anything like such that i should be including in order for the complier to recognize input_b();
:=Is my methodology correct? any suggestions will be helpful
:=Thank you
:=kamal
Original Post ID: 9458 |
