<font face="Courier New" size=-1>There`s a Problem !
I've to make a projekt.
I should get a 14 bit ttl datastram from an ir-receiver module and have to read this data with a pic16c745.
To control my hardware i have to compare this 14 bit wide code with an array of n codes with 14 bit.If there's a code which is equal the pic performs an operation.
I don't know how i can manage this !
Please help me !!
Yours chriss</font>
___________________________
Original Post ID: 9329
Tomi Guest
Re: Array in CCS, Please help me !!!!!!
Posted: Sun Nov 24, 2002 12:24 pm
What is about the good old "switch" statement something like this:
unsigned long indata; // ulong is 16 bit in CCS C
#define OPCODE1 0x3C01
#define OPCODE2 0x3C02
#define OPCODE3 0x3C03
#define OPCODEn 0xXXXX
indata = Receive_14_bits();
switch (indata) {
case OPCODE1: DoSomething1(); // first case
case OPCODE2: DoSomething2(); // 2nd case
........ // other cases
default: HandleError(); // none of above: illegal command
:=<font face="Courier New" size=-1>There`s a Problem !
:=I've to make a projekt.
:=I should get a 14 bit ttl datastram from an ir-receiver module and have to read this data with a pic16c745.
:=To control my hardware i have to compare this 14 bit wide code with an array of n codes with 14 bit.If there's a code which is equal the pic performs an operation.
:=I don't know how i can manage this !
:=Please help me !!
:=Yours chriss</font>
Original Post ID: 9341
