In order to directly read/write to internal registers, where can I find some header files with description of all internal registers of a microcontroller ?
i.e.
#BYTE TMR0 = 0x01
#BIT T0IF = 0x0B.2
Thanks !!!
dbotkin
Joined: 08 Sep 2003 Posts: 197 Location: Omaha NE USA
Posted: Thu Nov 16, 2006 8:53 am
The .H file for your processor will have some. For the common ones, I haven't found anything but it would be pretty simple to write using the data sheet. I usually just add a few #defines for any registers I need to set directly.
