helen Guest
modify timer(timer_1_high) |
Posted: Thu Dec 19, 2002 4:27 am |
<font face="Courier New" size=-1>hi there,
having problem with programming my picdem.net board with ethernet web server. i am using ccsc version pcm 3.XXX, and i changed the picweb.c code arcoding to the tips given by FAQ(ccsc web). I modify the code with #byte TIMER_1_HIGH = 0x0f, and #byte TIMER_1_LOW = 0x0e. However, the code loaded into my pic 16f877 cant work . Either than that, i does not do any changer more. Ops, the FAQ also mentioned about #device ADC=10, i test to modified, the result is error while compiling. Due to i do not need to implement ADC, i just identify timer_1_high and timer_1_low.
The code do not have problem, it can be compiler, the thing is, it cant work as the demo application board. If i load the demo application (p16web.h) given by ccsc, it's ok. The result is same wit what i hope for.
Can please give me a guide? i need to modify the demo application to suit with my application. But before that, i sure want to ensure that by using ccsc pcm version 3.XX, my board can work.
thank you.
helen
</font>
Original Post ID: 10133 |
helen Guest
Posted: Thu Dec 19, 2002 4:52 am |
Ops, besides trying insert the identifier for timer_1_high,and timer_1_low, i also try with #device ADC=10 as state by FAQ CCSC. the problem is error message while compiling.
thank you.
Original Post ID: 10134 |
