YulL
Joined: 29 Sep 2004 Posts: 39 Location: Paris (France)
Problem with structure |
Posted: Fri Nov 05, 2004 7:55 am |
I'm using two variables : CVM_CRC and PIC_CRC... CVM_Header, PIC_Header... etc... But now I prefer to use structures in order to make my code more readable!
Here is what I have already done for that :
struct BusMail
{ int8 longueur[2];
int8 prim[2];
int8 param[32];
int8 header;
int8 CRC;
int8 SuId;
int8 TxSeq;
int8 RxSeq;
int1 IC;
int1 PF;
} PIC, CVM;
void send_control(int8 PIC.SuId, int8 PIC.RxSeq, int8 PIC.PF);
void API_FP_INVOKE_ACCESS_RIGHTS(int8 PIC.TxSeq, int8 PIC.RxSeq);
void CVM_EEPROM_WRITE_REQ_BASE(int8 PIC.TxSeq, int8 PIC.RxSeq);
But when I compile I have the error message : "Expecting a , or )"
I can't find where I'm wrong...
Thanks by advance for your support. ![Razz](images/smiles/icon_razz.gif) |
asmallri
Posted: Fri Nov 05, 2004 8:26 am |
Code: | void send_control(int8 PIC.SuId, int8 PIC.RxSeq, int8 PIC.PF);
void CVM_EEPROM_WRITE_REQ_BASE(int8 PIC.TxSeq, int8 PIC.RxSeq); |
I assume you are showing the functional protypes. In which case they should be..
Code: | void send_control(int8 SuId, int8 RxSeq, int8 PF);
void API_FP_INVOKE_ACCESS_RIGHTS(int8 TxSeq, int8 RxSeq);
void CVM_EEPROM_WRITE_REQ_BASE(int8 TxSeq, int8 RxSeq); |
Then when you call one it would look like..
Code: | send_control(PIC.SuId, PIC.RxSeq, PIC.PF); |
_________________ Regards, Andrew
YulL
Posted: Mon Nov 08, 2004 3:40 am |
Thanks for your advice it works fine now!!
![Wink](images/smiles/icon_wink.gif) |
