18F452 wake up from SLEEP
Arash
PostPosted: Wed Jan 29, 2003 6:37 pm     Reply with quote
Does any one know why I can't wake up the 18F452 from sleep with the RDA_isr interrupt???
___________________________
Original Post ID: 11122
Tomi
Re: 18F452 wake up from SLEEP
PostPosted: Thu Jan 30, 2003 1:42 am     Reply with quote
Because the CPU clock is stopped under sleep. So the baud rate generator is also stopped.
If you want to use sleep and serial comm then tie the receive line to a bit of port_B.4-7 and use port_b change interrupt to wake up the PIC:
#int_RB
void __INTRB()
char inp;
inp = port_B; // read port_b
tosleep = 1; // give a small time
disable_interrupts(INT_RB); // disable further RB ITs
And before sleep in the main():
if (!tosleep) {
enable_interrupts(INT_EXT);
enable_interrupts(INT_RDA);
enable_interrupts(INT_RB); // re-enable RB IT
restart_wdt();
Sleep();
#asm
NOP
#endasm
:=Does any one know why I can't wake up the 18F452 from sleep with the RDA_isr interrupt???
Original Post ID: 11129
