Looking for PIC16F872 programmer to write a small code.
Sean Stevens
PostPosted: Sat Feb 08, 2003 9:40 am     Reply with quote
Hi
I am looking for a competent PIC programmer to write a fairly simple code for a project. I am willing to pay.
The project is as follows: a special hardware connects to a USB port and presents the data from USB port in pure 8bit format with associated Read/Write signal lines to the PIC 872. The PIC is to read the data and pass it to a smart card memory card. I have done all the hardware. I also have the source code for this written for 872 but it doesnt seems to work.
Ideally looking to hook up with a software partner to do projects for commercial use, if interested drop me a line.
Thanks very much.
Sean
UK
___________________________
Original Post ID: 11424
Sergio
Re: Looking for PIC16F872 programmer to write a small code.
PostPosted: Sat Feb 08, 2003 10:53 pm     Reply with quote
Hi Sean,
I'm a design engineer in Arkansas, USA. Been using PICs pretty much since they came out.
Tell me more about the project. I might be interested. Why are you using the F872?
What part of the UK? I was in Manchester and the northern part of England on business a few years ago. Saw Manchester United play! What a day that was!
Cheers,
Sergio
:=Hi
:=I am looking for a competent PIC programmer to write a fairly simple code for a project. I am willing to pay.
:=The project is as follows: a special hardware connects to a USB port and presents the data from USB port in pure 8bit format with associated Read/Write signal lines to the PIC 872. The PIC is to read the data and pass it to a smart card memory card. I have done all the hardware. I also have the source code for this written for 872 but it doesnt seems to work.
:=Ideally looking to hook up with a software partner to do projects for commercial use, if interested drop me a line.
:=Thanks very much.
:=Sean
:=UK
Original Post ID: 11437
