compiler does not know16f690
Banic
PostPosted: Fri Feb 23, 2007 3:09 pm     Reply with quote
Hi
It was working before but now(after reinstalling the WINDOWS XP) the pcm compiler does not know the 16f690part. I use MPLAB with pcm and pch all together. The 16f688 it knows. What is the problem?
Thanks Brano
PostPosted: Fri Feb 23, 2007 4:04 pm     Reply with quote
Make sure you re-install a version of the CCS compiler that supports
the 16F690. Also, make sure you re-install a version of MPLAB that
supports it.
