sonicdeejay
Problem when doing test run on LCD using flex_lcd Driver |
Posted: Fri Feb 03, 2006 12:51 pm |
Guys....
Since my PIC18F2525 is used port B for LCD,I change this in the driver code,,,
Code: | #define LCD_DB4 PIN_B0
#define LCD_DB5 PIN_B1
#define LCD_DB6 PIN_B2
#define LCD_DB7 PIN_B3
#define LCD_E PIN_A1
#define LCD_RS PIN_A3
#define LCD_RW PIN_A2 |
I am tried to compile the following sample code to try out LCd panel using flex_lcd driver....
FLEX_LCD
Code: | #include <18F2525.h>
#include <flex_lcd.c>
#device ICD=TRUE
#device ADC=10
#use delay(clock=16000000) // 16Mhz Crystal is Used
#use rs232(baud=9600, parity=N, xmit=PIN_C6, rcv=PIN_C7, bits=8) // RS232 Configuration
#include <stdlib.h>
output_high(PIN_A1);
output_low(PIN_A1);
printf(lcd_putc, "Hello World.");
and I have compile error in flex_lcd.c side...
It gives error on
Code: | delay_us(60); and error message is unidentified indentifier delay_us |
How can I solve this prob??? I know I need must b using those delay to display properly.[/quote] |
Posted: Fri Feb 03, 2006 1:21 pm |
The drivers use CCS library routines to do delays, such as delay_us().
So you must put the #include file below the #use delay() statement.
Example:
#device ICD=TRUE
#device ADC=10
// Always put your source code #include files down here.
#include <flex_lcd.c> |
sonicdeejay
Posted: Sat Feb 04, 2006 5:11 am |
gotcha...thx for the support
sonic
sonicdeejay
Posted: Mon Feb 06, 2006 4:39 am |
Dear PCM programmer,,
My LCD is use S6A0069 as controller....
so can I use FLEX_LCD.c as the driver???? |
