PCH FSR access
Paul Kleissler
PCH FSR access
PostPosted: Thu Dec 26, 2002 1:53 pm     Reply with quote
How can I define the FSR names to the memory location in PCH. In PCM I would create a #Byte statement with the memory address of the FSR in question. This method doesn't seem to work for PCH though.
Paul
___________________________
Original Post ID: 10263
Kurt Franke
Re: PCH FSR access
PostPosted: Thu Dec 26, 2002 5:57 pm     Reply with quote
Paul,
Well, I don't understand why it should do this, but the compiler clears the high FSR when you write to the low one..
Example:
.................... FSR0H = 0x01;
0012: MOVLW 01
0014: MOVWF FEA
.................... FSR0L = 0xFF;
0016: CLRF FEA <--- Huh???
0018: MOVLW FF
001A: MOVWF FE9
So... just write your values to the low FSR first, then the
high one.
This program works:
#include <18f452.h>
#byte FSR0L = 0xFE9
#byte FSR0H = 0xFEA
#byte INDF0 = 0xFEF
void main ()
FSR0L = 0xFF;
FSR0H = 0x01;
INDF0 = 0xAA; // writes 0xAA to 0x1FF
good luck,
Kurt
:=How can I define the FSR names to the memory location in PCH. In PCM I would create a #Byte statement with the memory address of the FSR in question. This method doesn't seem to work for PCH though.
:=Paul
Original Post ID: 10264
Tomi
Re: PCH FSR access
PostPosted: Fri Dec 27, 2002 5:36 am     Reply with quote
There is a small confuse in CCS C about byte/word registers.
This works for me:
#byte FSR0 = 0xFE9
FSR0 = 0x1234;
The list:
.................... FSR0 = 0x1234;
0342: MOVLW 12
0344: MOVWF FSR0H
0346: MOVLW 34
0348: MOVWF FSR0L
As you can see FSR0 is defined as a single byte but a write attempt handles it as a 16-bit word Smile
I think this is true for Timer registers, etc. (16-bit hardware registers)
:=Paul
Original Post ID: 10270
Mark
Re: PCH FSR access
PostPosted: Fri Dec 27, 2002 9:21 am     Reply with quote
In that case, CCS will probably change it and it will no longer work in the future. Why not do it this way?
long FSR0;
#locate FSR0 = 0xFE9
FSR0 = 0x1234;
Regards,
Mark
:=There is a small confuse in CCS C about byte/word registers.
:=This works for me:
:=#byte FSR0 = 0xFE9
:=FSR0 = 0x1234;
:= The list:
:=.................... FSR0 = 0x1234;
:=0342: MOVLW 12
:=0344: MOVWF FSR0H
:=0346: MOVLW 34
:=0348: MOVWF FSR0L
:=As you can see FSR0 is defined as a single byte but a write attempt handles it as a 16-bit word <img src="http://www.ccsinfo.com/pix/forum/smile.gif" border="0">
:=I think this is true for Timer registers, etc. (16-bit hardware registers)
:=:=How can I define the FSR names to the memory location in PCH. In PCM I would create a #Byte statement with the memory address of the FSR in question. This method doesn't seem to work for PCH though.
:=:=Paul
Original Post ID: 10271
Paul Kleissler
Re: PCH FSR access
PostPosted: Fri Dec 27, 2002 2:55 pm     Reply with quote
Great Ideas I will give them a try.
Paul
:=In that case, CCS will probably change it and it will no longer work in the future. Why not do it this way?
:=long FSR0;
:=#locate FSR0 = 0xFE9
:=FSR0 = 0x1234;
:=Regards,
:=Mark
:=:=There is a small confuse in CCS C about byte/word registers.
:=:=This works for me:
:=:=#byte FSR0 = 0xFE9
:=:=FSR0 = 0x1234;
:=:= The list:
:=:=.................... FSR0 = 0x1234;
:=:=0342: MOVLW 12
:=:=0344: MOVWF FSR0H
:=:=0346: MOVLW 34
:=:=0348: MOVWF FSR0L
:=:=As you can see FSR0 is defined as a single byte but a write attempt handles it as a 16-bit word <img src="http://www.ccsinfo.com/pix/forum/smile.gif" border="0">
:=:=I think this is true for Timer registers, etc. (16-bit hardware registers)
:=:=:=How can I define the FSR names to the memory location in PCH. In PCM I would create a #Byte statement with the memory address of the FSR in question. This method doesn't seem to work for PCH though.
:=:=:=Paul
Original Post ID: 10274
