#asm and pic18 access bank
DuncanH
PostPosted: Tue Dec 10, 2002 2:42 am     Reply with quote
can anyone tell me how to use the access bank when doing #asm commands with the pic18. internally ccs use
bcf xd8,0 // status register carry bit
but when you put this in the source it throws an error
___________________________
Original Post ID: 9926
R.J.Hamlett
Re: #asm and pic18 access bank
PostPosted: Tue Dec 10, 2002 5:21 am     Reply with quote
:=can anyone tell me how to use the access bank when doing #asm commands with the pic18. internally ccs use
:=bcf xd8,0 // status register carry bit
:=but when you put this in the source it throws an error
It would do.
'xd8', is a label, and you will get an undefined label error (unless you have something defined called 'xd8'). The syntax for a hexadecimal number, is '0xd8', which will work fine.
Original Post ID: 9928
DuncanH
PostPosted: Tue Dec 10, 2002 10:35 am     Reply with quote
:=:=can anyone tell me how to use the access bank when doing #asm commands with the pic18. internally ccs use
:=:=bcf xd8,0 // status register carry bit
:=:=but when you put this in the source it throws an error
:=It would do.
:='xd8', is a label, and you will get an undefined label error (unless you have something defined called 'xd8'). The syntax for a hexadecimal number, is '0xd8', which will work fine.
Sorry I did not explain enough the xd8 shows that it is using the access bank to do fast ram read and write the actual address of the status is 0xfd8 but when you use the access bank addressing you do not need to put the F at the begining however although there is a tempting glimpse of it in the documetation I cannot see anyway of getting it working from my source. See #asm in help file pic 18
bcf f,b,a - does a mean access or what it is not defined
Original Post ID: 9938
R.J.Hamlett
PostPosted: Tue Dec 10, 2002 12:28 pm     Reply with quote
:=:=:=can anyone tell me how to use the access bank when doing #asm commands with the pic18. internally ccs use
:=:=:=bcf xd8,0 // status register carry bit
:=:=:=but when you put this in the source it throws an error
:=:=It would do.
:=:='xd8', is a label, and you will get an undefined label error (unless you have something defined called 'xd8'). The syntax for a hexadecimal number, is '0xd8', which will work fine.
:=Sorry I did not explain enough the xd8 shows that it is using the access bank to do fast ram read and write the actual address of the status is 0xfd8 but when you use the access bank addressing you do not need to put the F at the begining however although there is a tempting glimpse of it in the documetation I cannot see anyway of getting it working from my source. See #asm in help file pic 18
:=bcf f,b,a - does a mean access or what it is not defined
You are missing the point of my reply. You are actually complaining about the wrong error. :-)
You cannot use the syntax 'xf8', because this will be seen as a variable, not an address. This has to be preceeded with the '0', to tell the compiler that this is an address. The code fed into the compiler has to use the 'C' syntax, rather than assembler syntax.
Now the actual syntax of the assembler required for the access bank, is defined in the Microchip data sheet, with a=0, implying access bank, and a=1, implying to use the BSR. This value goes into bit 0 of the MSByte of the resulting instruction. If you look at the hex output that is generated for the code.
The required syntax to correctly override the access bank, then would be:
#asm
bcf 0xd8,0,0
#endasm
The instruction:
#asm
bcf 0xd8,0
#endasm
Will produce exactly the same assembler as you show...
Unfortunately, the compiler does not (yet) recognise the second ',0', and instead complains on this (not on the 'xd8').
So the point is that your 'example' given, is failing, because you are trying the wrong thing (xd8), not because of the access bank...
I had the same problem some time ago, with the internal compiler not handling the 'RETFIE 1' syntax, again despite the help file showing the full syntax. I complained about this to CCS (and in the meantime just coded round it by using the #rom directive to put the correct byte in the location). CCS fixed this very quickly, and do now accept this syntax.
Try actually inputing what I showed. This doesn't give the access bank override, but is compatible with what CCS are generating at present.
Original Post ID: 9947
DuncanH
PostPosted: Tue Dec 10, 2002 1:55 pm     Reply with quote
:=:=:=:=can anyone tell me how to use the access bank when doing #asm commands with the pic18. internally ccs use
:=:=:=:=bcf xd8,0 // status register carry bit
:=:=:=:=but when you put this in the source it throws an error
:=:=:=It would do.
:=:=:='xd8', is a label, and you will get an undefined label error (unless you have something defined called 'xd8'). The syntax for a hexadecimal number, is '0xd8', which will work fine.
:=:=Sorry I did not explain enough the xd8 shows that it is using the access bank to do fast ram read and write the actual address of the status is 0xfd8 but when you use the access bank addressing you do not need to put the F at the begining however although there is a tempting glimpse of it in the documetation I cannot see anyway of getting it working from my source. See #asm in help file pic 18
:=:=bcf f,b,a - does a mean access or what it is not defined
:=You are missing the point of my reply. You are actually complaining about the wrong error. :-)
:=You cannot use the syntax 'xf8', because this will be seen as a variable, not an address. This has to be preceeded with the '0', to tell the compiler that this is an address. The code fed into the compiler has to use the 'C' syntax, rather than assembler syntax.
:=Now the actual syntax of the assembler required for the access bank, is defined in the Microchip data sheet, with a=0, implying access bank, and a=1, implying to use the BSR. This value goes into bit 0 of the MSByte of the resulting instruction. If you look at the hex output that is generated for the code.
:=The required syntax to correctly override the access bank, then would be:
:=#asm
:= bcf 0xd8,0,0
:=#endasm
:=The instruction:
:=#asm
:= bcf 0xd8,0
:=#endasm
:=Will produce exactly the same assembler as you show...
:=Unfortunately, the compiler does not (yet) recognise the second ',0', and instead complains on this (not on the 'xd8').
:=So the point is that your 'example' given, is failing, because you are trying the wrong thing (xd8), not because of the access bank...
:=I had the same problem some time ago, with the internal compiler not handling the 'RETFIE 1' syntax, again despite the help file showing the full syntax. I complained about this to CCS (and in the meantime just coded round it by using the #rom directive to put the correct byte in the location). CCS fixed this very quickly, and do now accept this syntax.
:=Try actually inputing what I showed. This doesn't give the access bank override, but is compatible with what CCS are generating at present.
Thanks for the help. I knew that the correct address was 0x?? but it was how I was suppposed to make it use the access bank that was the problem for me. However you have answered the question in the first part of this reply. all we have to do now is get the compiler to use it!! thanks again
Original Post ID: 9951
