gmua
| LCD 2x16 Driver for MikroElektronika EasyPic v7 Board |
Posted: Wed Jan 25, 2012 10:07 pm |
| PCM programmer wrote: | Why use it ?
2. If you're a newbie and your board isn't configured to use the CCS driver, and you don't
know how to modify it or Mark's driver, then this driver can get you up running quickly.
I modified the following lines to make the LCD work with the EasyPic v7 and CCS C and is working great.
// These pins are for the MikroElektronika EasyPIC v7 Board
#define LCD_DB4 PIN_B0
#define LCD_DB5 PIN_B1
#define LCD_DB6 PIN_B2
#define LCD_DB7 PIN_B3
#define LCD_E PIN_B5
#define LCD_RS PIN_B4
// #define LCD_RW PIN_A2
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
// #define USE_LCD_RW 1
Thanks a lot PCM programmer. |
wordizlife
Posted: Tue Apr 17, 2012 2:34 pm |
Just wanted to thank you for this great post. Very user friendly coding, very appreciated!  |
Velraj
| 8 bit flex_lcd |
Posted: Tue Mar 11, 2014 5:21 am |
| Can anyone code for 8bit flex_lcd ?? |
cyril.carlita
| drive for lcd 1602 |
Posted: Thu Jul 20, 2023 7:00 am |
Hello, i try the first driver for 2x16 ligne but lcd_gotoxy function don't work for me.
I can't go to the ligne 2 with lcd_gotoxy(1,2) , Why?
Can you show me a driver that work for 2x16 lignes? |
cyril.carlita
Posted: Thu Jul 20, 2023 11:53 am |
| Finnaly, it work for me |
Posted: Sun Apr 05, 2026 9:28 am |
the 'standard' way to get that effect is to simply REM out the pin defines at
the head of the driver, and then use this with the defines moved to your main
code. You can then set them here without changing the driver again.
If you want to do it with an ifdef, then:
#ifndef LCD_DB4
//Use default pins if not already defines
// These pins are for my Microchip PicDem2-Plus board,
// which I used to test this driver.
// An external 20x4 LCD is connected to these pins.
// Change these pins to match your own board's connections.
#define LCD_DB4 PIN_D4
#define LCD_DB5 PIN_D5
#define LCD_DB6 PIN_D6
#define LCD_DB7 PIN_D7
#define LCD_RS PIN_E0
#define LCD_RW PIN_E1
#define LCD_E PIN_E2
This way the driver will default to the standard pins if they are not aleady
defined. |
