Posted: Fri Dec 16, 2016 4:21 pm |
See if this program runs for you. I was able to make it work with an
18F46K22 (I don't have an 18F43K22, but it's the same PIC family).
I used MPLAB 8.92 and CCS vs. 5.065. I tested this with a PicDem2-Plus
board. It displays "Start: ", and then it echoes any keys that you type.
Make sure Local Echo is turned off on your terminal program. I used
TeraTerm for this test. I edited the PIC below to be the one you're using.
Also, I am compiling with MPLAB set for "Release" mode.
#include <18F43K22.h>
#fuses NOWDT,PUT,BROWNOUT
#use delay(internal=64M)
char c;
delay_ms(5); // Allow time for the PLL to start-up
printf("\n\rStart: ");
c = getc();
putc(c);
Posted: Sat Dec 17, 2016 3:36 am |
Realistically, the first thing you should do when you have any apparently 'clock' related problem, is step back to the old 'flash an led' test.
A literally sub ten line section of code, just setting up the oscillator and flashing an LED. So:
#use delay(clock=16M)
output_toggle(PIN_A0);
Now if we build this, we can see straight away it runs wrong. The reason is simple. You are not selecting the internal oscillator, and it defaults to the external. This is not present, so it does a 'fail safe clock monitor' and switches to the internal oscillator at 1Mhz, and runs 16* slower than it should.
So we then use PCM_Programmer's basic fuse settings, and try:
#fuses NOWDT,PUT,BROWNOUT,NOLVP //prefer to specify NOLVP
#use delay(internal=16M)
Low and behold it starts flashing at the right rate.
Basically the reason the code is not working, is that you are not setting up the oscillator. It goes to a default that is 1/64th of the specified clock value (if you specify 64MHz), so gives 320baud when you select 19200 (not actually 300, but nearly). |
