code to measure frequency
Goto page 1, 2  Next
PostPosted: Sun Oct 03, 2010 1:10 pm     Reply with quote
I successfully converted the Count program to run with an 18F-series
PIC. I tested it with an 18F452, with CCS compiler vs. 4.112. I ran it
on a PicDem2-Plus board (non-Rohs version). I used a B&K Model 4011
function generator to apply a 5v p/p squarewave signal to pin B0 on
the PIC. The program's output was displayed on TeraTerm terminal
window, running on a Windows XP system. The PIC runs at +5 volts.
With a 4 MHz crystal on the 18F452, it could correctly determine the
input signal frequency over a range of 1 Hz to 24.8 KHz. With a 20 MHz
crystal on the PIC (and with the HS fuse), it worked over a range from
1 Hz to 65.5 KHz. No adjustments are needed to the count_18f.c program
to make it work with a different crystal. Just re-compile it. (But
remember to change the oscillator #fuse and the #use delay() value
in your test program).
Here is the test program. Note that the test program has the possibility
of using the PIC's own PWM module to generate a test signal, by putting
a jumper from pin C2 to pin B0. I didn't use that feature for the formal
testing. I used a B&K function generator to make the test signal.
#include <18F452.H>
#fuses XT, NOWDT, BROWNOUT, PUT, NOLVP
#include "count_18f.c"
int16 result;
// Create a test signal from the same PIC that is
// measuring the signal.  Then we don't need an
// external frequency generator.  The PIC supplies it.
// Use the hardware PWM module to generate the signal.
// Connect a jumper from pin C2 to pin B0 for this test.
// This will put a 244 Hz squarewave on pin B0.
//setup_ccp1(CCP_PWM);
//setup_timer_2(T2_DIV_BY_16, 255, 1);  // PWM freq = 244 Hz (@ 4 MHz)
//set_pwm1_duty(128);  // 50% duty cycle.
// Call the COUNT function to measure the frequency.
// Measure the number of counts in one second
// from the input signal on Pin B0.  This will
// be the frequency (in Hz) of that signal.
   result = count(PIN_B0, 1000); // Get count on Pin B0 for 1000 ms
   printf("%lu\n\r", result);
Here is the count_18f.c program. It contains the count() function.
This file must be #include'd in your test program.
#define BYTE_PTR(x) &(int8 *)(x)
#define COUNT_DELAY ((int16)(getenv("CLOCK") / 80000))
// ASM definitions
#define W  0
#define F  1
// Status Register Bits
#define Z  2
#define C  0
// Register addresses (18F)
#byte INDF0  = 0xFEF
#byte STATUS = 0xFD8
#byte FSR0H  = 0xFEA
#byte FSR0L  = 0xFE9
int16 count(int16 ccs_pin, int16 period)
int8 const bitmask_table[] = {0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
int16 io_port;
int8  bitmask;
int16 R0;
int16 R1;
int16 R2;
int16 R3;
int32 loop_count;
// These variables are used in the ASM code
// and must be located in the same RAM bank.
#locate R0      = 0x30
#locate R1      = 0x32
#locate R2      = 0x34
#locate R3      = 0x36
#locate io_port = 0x38
#locate bitmask = 0x3A  // *** Changed to 0x3A for 18F version ***
// Extract the Port address and bitmask from
// the CCS pin number.
io_port = ccs_pin >> 3;
bitmask = bitmask_table[ccs_pin & 7];
// Set the pin to be an input pin.
output_float(ccs_pin);
// Calculate the number of loop iterations to do.
loop_count = _mul(period, COUNT_DELAY);
// Put loop_count into R0 (msb), R2+1 (mid), R2 (lsb)
R0 = make8(loop_count, 2);  // msb
(int8)R2 = make8(loop_count, 1);  // Get mid into  R2
R2 <<= 8;  // Move mid into R2+1
(int8)R2 = make8(loop_count, 0); // lsb
#asm
    movf    io_port, W      ; Get port lsb
    movwf   FSR0L
    movf    BYTE_PTR(io_port) +1, W   ; Get port msb
    movwf   FSR0H
    incf    R0, F              ; Bump up high and mid for dec
    incf    BYTE_PTR(R2) +1, F
    clrf    R1                 ; Zero counter
    clrf    BYTE_PTR(R1) +1
    movf    INDF0, W
    andwf   bitmask, W         ; Isolate it
    movwf   R3                 ; Save starting state as last
countloop:                     ; 20 usec loop (at 4 MHz)
    nop                        ; 1
    movf    INDF0, W           ; 1
    andwf   bitmask, W         ; 1 Isolate it
    movwf   BYTE_PTR(R3) +1    ; 1 Save state
    xorwf   R3, W              ; 1 Compare with last time
    andwf   BYTE_PTR(R3) +1, W ; 1 Only count high states
    xorwf   bitmask, W         ; 1 Flip for next test
    btfsc   STATUS, Z          ; 1 / 2
    incf    R1, F              ; 1 / 0 Count pulse
    incf    BYTE_PTR(R1) +1, F ; 1 / 0
    movf    BYTE_PTR(R3) +1, W ; 1 Set new last state
    movwf   R3                 ; 1
    decf    R2, F              ; 1 Count time
    decf    BYTE_PTR(R2) +1, F ; 1 / 0
    decfsz  R0, F              ; 1 / 2
    goto    countloop          ; 2 / 0
    movf    R1, W              ; Result to W
#endasm
return(R1);  // R1 holds the result
flyingjoint
PostPosted: Wed Oct 13, 2010 1:06 pm     Reply with quote
Hello, I also need a frequency counter and I'm using a PIC 16F874A. But my question about the frequency counter posted here is:
- Does the counter works for a 20MHz crystal?
- Would this increase the range of frequency counting?
Let's rock!
PostPosted: Wed Oct 13, 2010 1:09 pm     Reply with quote
Did you read my post immediately above your post ?
Every question you asked is answered, in detail.
matheuslps
PostPosted: Sat Jun 25, 2011 4:19 pm     Reply with quote
I need to measure 3 square wave signals.
I am using a 16F877A. For 2 signals I am using the CCP1 and CCP2 module. It is working very fine.
For the third signal, can I use this count.c file?
The signal go from 70hz to 7khz maximum.
bye
PostPosted: Sat Jun 25, 2011 4:30 pm     Reply with quote
If you run them all at the same time, the count.c code will be interrupted
by #int_ccp1 and #int_ccp2. The counting process will be stopped while
the interrupts are processed. This will reduce the accuracy of the count code.
Of course, you could stop using the CCP interrupts for a while by calling
the disable_interrupts() function for each one. Then you could safely
call the count() function and measure the 3rd signal. When that's done,
re-enable the CCP interrupts.
matheuslps
PostPosted: Sat Jun 25, 2011 4:51 pm     Reply with quote
Sure....
Thanks...
My readings will not be at real time, so it will work.
Let me make some test here.
bye
matheuslps
PostPosted: Sat Jun 25, 2011 7:12 pm     Reply with quote
Just a feedback:
I was having problems with my code to measure 3 frequencies using the CCP1, CCP2 and the code count.c posted.
The problem was change from each interrupt.
So i changed my approach and did all the thing with a different way:
I setup the TIMER1 to make a delay of 0.5 seconds (500mS) and count the number of pulses over the CCP1, CCP2 and RB0 using the INT_EXT interrupt.
Then i multiplied them by 2 and got everything fine. I using a 4Mhz crystal, so if I need to change, simple make change the factor 2. The code is very small, look:
#include <16f877a.h>             //O PIC utilizado, obigatório!
                                 //ser utilizado de 8 bits também.
#FUSES NOWDT                     //Sem Watch dog, evitando reset
#FUSES XT                        //Crystal de oscilação igual a 4mhz
#FUSES PUT                       //Tempo de início do PIC
#FUSES NOPROTECT                 //Codigo sem proteção de leitura, software livre!
#FUSES NOLVP                     //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD                     //No EE protection
#use delay(clock=4000000)        //Meu clock
#include <LCD.C>                 //Rotina de LCD modo 4 vias. Obrigatório!
int16 freq_1=0, freq_2=0,freq_3;
int1 flag;
int16 p, q,r;
int8 cont;
#int_timer1
void trata_timer1(void)
   flag=1;
   p = freq_1*2;
   q = freq_2*2;
   r = freq_3*2;
   freq_1 = 0;
   freq_2 = 0;
   freq_3 = 0;
   set_timer1(3036);
#int_ccp1
void ccp1_int()
   freq_1++;
#int_ccp2
void ccp2_int()
   freq_2++;
#int_ext
void trata_ext()
   freq_3++;
   setup_ccp1(CCP_CAPTURE_RE);
   setup_ccp2(CCP_CAPTURE_RE);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
   enable_interrupts(int_ccp1);
   enable_interrupts(int_ccp2);
   enable_interrupts(int_timer1);
   enable_interrupts(int_ext);
   enable_interrupts(global);
   set_timer1 (3036);
   while (TRUE)
      if (flag == 1)
         printf (lcd_putc,"\fF_1:%lu\nF_2:%lu F_3:%lu",p,q,r);
         delay_ms (200);
         flag=0;
And a simulation:
Thanks everyone.
jrgob
PostPosted: Fri Sep 23, 2011 8:03 am     Reply with quote
I need help to make a frequency meter of to 200 kHz...
I'm using the code of matheuslps, but I could not change to read to 200KHz, someone could help me!
Thanks.
jrgob
Goto page 1, 2  Next
Page 1 of 2
