PIC16F1824 INT_RDA does not work
PostPosted: Fri Feb 10, 2012 7:34 pm     Reply with quote
The PIC data sheet says you have to set the APFCON0 bits to 1,
in order to select the alternate pins. I did that and it works:
#include <16F1824.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PLL_SW, NOLVP
#use delay(clock=4M)
#byte APFCON0 = getenv("SFR:APFCON0")
#bit TXSEL = APFCON0.2
#bit RXSEL = APFCON0.7
#int_RDA
void  RDA_isr(void)
char c;
c = getc();
putc(c);
TXSEL = 1;
RXSEL = 1;
clear_interrupt(INT_RDA);
enable_interrupts(INT_RDA);
Beowulf
PostPosted: Fri Feb 10, 2012 8:53 pm     Reply with quote
just updated to the 4.129 software version.
this no longer appears in the LST file in the default case(tx=C4,rx=C5)
0056:  MOVLB  02
0057:  BSF    1D.2
0058:  BSF    1D.7
I am no longer at my work bench ...so I can't load this onto the PIC to be sure...but It seems as though the 4.128 version has a bug when compiling for this processor. If I have time this weekend I will try this out to see if it works on the PIC.
Beowulf
(Solved)
PostPosted: Mon Feb 13, 2012 9:15 am     Reply with quote
I listed my compiler version incorrectly in the problem statement. The version that has this issue is:
CCS PCM C Compiler, Version 4.124
I am convinced that this was a compiler bug. I upgraded to 4.129 and the problem has gone away. Th tx/rx pins are correctly assigned now and the interrupts occur as expected.
**always check for updates**
Re: (Solved)
PostPosted: Mon Feb 13, 2012 9:23 am     Reply with quote
No!.
Not if the compiler works for what you want.....
Key here is that the 1824 is a pretty new chip, and it always seems to take CCS perhaps a dozen versions to get these working.
However CCS's 'updates', generally are not reliable till they have been tested for a while, so rule has to be 'check for updates _if_ you have something not working right'. Otherwise you may well be asking for problems.....
Beowulf
PostPosted: Mon Feb 13, 2012 11:27 am     Reply with quote
you are correct....updates are only useful when there is an actual problem to solve...
