Posted: Thu Nov 20, 2008 3:01 pm |
You didn't post the #include, #fuses, #use delay(), or #use rs232()
statements. Also, you don't need to copy and paste the get_string()
function. Just #include the input.c file. Here's a test program.
Make a program similar to this and see if you can type in a string
in a terminal program on your PC, and get the PIC to receive it
and send it back to the PC.
Code: | #include <16F877.H>
#include <input.c>
char temp[10];
printf("Enter string: ");
get_string(temp, sizeof(temp));
printf("\n\rReceived: %s \n\r", temp);
coderchick
Posted: Thu Nov 20, 2008 8:12 pm |
Code: | #include <stdlib.h>
#include <input.c>
#include <16F887.h>
#FUSES XT //Crystal osc <= 4mhz for PCM/PCH
#FUSES PUT //Power Up Timer
#FUSES NOLVP //No low voltage prgming,
#FUSES BORV40 //Brownout reset at 4.0V
#use rs232(baud=57600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8) |
in a terminal program on your PC |
Using that program I was able to communicate with my PIC through the terminal with no problems. I can also use the terminal to communicate with the driver, however, I still can't combine the two. Now what? The terminal program proves that my code can potentially use the get_string function, and I've been able to prove that I can talk to the driver through the terminal, so now, how do I subtract the terminal and get the two boards talking to each other? _________________ KMoe
~We the willing, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, for so long, with so little. We are now qualified to do anything with nothing -M. Theresa |
Posted: Thu Nov 20, 2008 8:43 pm |
get_string() expects a carriage return to mark the end of a string.
Do you have a '\r' escape sequence at the end of your strings
in your Master PIC code ? Example:
coderchick
Posted: Fri Nov 21, 2008 6:56 pm |
Yes, the driver sends out a carriage return of 13, 10, which is standard. I have no control or access to how the driver sends things, but I do know for a fact that it sends out a standard CR.
I guess my PIC is the Master PIC you are referring to in which case I'm using puts instead of printf, which already has the CR behind it. But the driver is receiving the data I send out no problem, it's my PIC receiving the data the driver is sending out that is giving me issues. _________________ KMoe
Posted: Fri Nov 21, 2008 7:03 pm |
Don't put any delays before you call get_string(). In your original code,
you have a 500 us delay after you send the command to start sending
the data. That delay can cause you to miss incoming characters if
more than 3 of them come in during that time. |
