				 Posted: Sat May 05, 2007 1:00 am     |
				With respect pin to C5, it's behaving correctly for the Full Bridge mode.
It's the P1A pin in that mode.   According to Figure 11-6 in the 16F685
data sheet, pin C5 will be either a constant high or a constant low,
depending upon whether you're going in forward or reverse.
So pin C5 is OK.
There is a note in Section 11.5 of the data sheet (PWM Enhanced mode).
It says:
 	  | Quote: | 	 		  | The TRIS register value for each PWM output must be configured appropriately. |
However, the ASM code generated by the compiler doesn't do this.
It only sets pin C5 as a low-level output pin.   It leaves the other pins
(C2, C3, C4) in the default state, which is as input pins.
Here's something you could try.   Add a line of code after each
setup_ccp1() function, to manually force pins C2-C5 to be outputs.
Add the lines shown in bold below.
 	  | Quote: |
#include <16F685.h>
#fuses XT,NOWDT,BROWNOUT,PUT
#use delay (clock=4000000)
// Setup the ECCP for PWM in full bridge mode.
setup_ccp1(CCP_PWM_FULL_BRIDGE | CCP_PWM_H_H);
set_tris_c(0xC3); // Set pins C2-C5 as outputs
setup_timer_2(T2_DIV_BY_1, 255, 1);
set_pwm1_duty(100);
// Switch the H-Bridge outputs between forward
// and reverse every 5 seconds.
   // Run forward for 5 seconds.
   delay_ms(5000);
   // Run in reverse for 5 seconds.
   setup_ccp1(CCP_PWM_FULL_BRIDGE_REV  | CCP_PWM_H_H);
   delay_ms(5000);
Then compile it and program it.   Then when it's running, look at pin C2
in forward mode, and pin C4 in reverse mode.    You should see PWM
pulses on them. |
