yes when I use more memory program a error message appear:" out of rom,the segment or the program is too large Main".
Posted: Sat Apr 05, 2008 9:57 am
In CCS, a function can't be larger than a ROM page. For the 16F877,
a ROM page is 2048 words. The solution is to break up the code in
main() and put some of it into functions. Then call those functions from
main(). This will allow the compiler to put those functions into other
ROM segments, and you won't get the "out of rom" error anymore.
Example:
void func1(void)
// code
void func2(void)
// code
// Initial main code goes here.
// Put some of the main() code into these functions.
func1();
func2();
// or more.
// Other main code goes here.
rnielsen
Posted: Mon Apr 07, 2008 8:55 am
There have been several posts regarding this error. Do a search on 'out of rom' and you should find the answers you are looking for.
Ronald
WASSIM
Posted: Mon Apr 07, 2008 10:23 am
also you must add #separate before the main function
