RS232 transmits data incorrectly. Why?
stefan_d6
PostPosted: Wed Aug 22, 2007 6:26 am     Reply with quote
I finally solved the problem.
I just changed the baud rate to 19 200 and rs232 works without errors. However I didn't find out way rs232 didn't work correctly with 9600 baud rate. I also removed int_rda and instead I use kbhit() - I think my code allows such construction without any loss of data. Am I right?
#include <18F1320.h>
#use delay(clock=20000000)
#use rs232(baud=19200, xmit=PIN_B1, rcv=PIN_B4,ERRORS)
#include <stdlib.h>
#include <input.c>
   float rps,rpm;
   long turns,duty;
   char cmd,no;
   setup_ccp1(CCP_PWM);
   setup_timer_2(T2_DIV_BY_1, 255, 1);  //The cycle time will be (1/clock)*4*t2div*(period+1)
                                        // tcycle = (1/20000000)*4*1*256 = 51.2us  ->  19.53125kHz
   set_pwm1_duty(0);                    // duty = tcycle*clock/t2div
                                        // 20% -> 10.24us x 20MHz = 204.8 ~205
                                        // 50% -> 25.6 x 20 = 512
   setup_timer_0(RTCC_EXT_L_TO_H);
   printf("--- Test program ---");
   while(true)
      if(kbhit())
         cmd =getc();
         switch(cmd)
         case 'n':set_timer0(0);
                  no=getc();
                  turns=get_timer0();
                  rps=(float)turns/36;
                  rpm=rps*60;
                  printf("\r\n%6.3f",rpm);
         case 'd':duty=get_long();
                  set_pwm1_duty(duty);
                  printf("\r\nduty = %Lu",duty);
         default :printf("\r\nError");
Douglas Kennedy
PostPosted: Wed Aug 22, 2007 9:17 am     Reply with quote
You should take a long look at Ttelmahs advice. Very very often the only way to get absolutely reliable RS232 reception is with a very short interrupt service routine that feeds a circular buffer. There must be now be dozens of issues with RS232 almost all were solved with the circular buffer approach. It's not that you can't find another way it is just not likely to work as well as Ttelmahs advice.
