PWM on the 16f877A
PostPosted: Sun Jun 05, 2005 3:06 pm     Reply with quote
I took your program, cleaned up everything that was wrong with it,
got rid of everything that wasn't necessary for testing pwm, and
now it works. On pins 16 and 17 of my 40-pin DIP 16F877A,
I get a 38.7 KHz signals, with a 25% duty cycle. I'm running the
PIC at +5v.
#include <16f877A.h>
#fuses HS, NOWDT, NOPROTECT, PUT, BROWNOUT, NOLVP
#use delay(clock=20000000)
int16 pwm_l, pwm_r;
setup_ccp1(CCP_PWM);
setup_ccp2(CCP_PWM);
setup_timer_2(T2_DIV_BY_1, 128, 1);
pwm_l = 128;
pwm_r = 128;
set_pwm1_duty(pwm_l);
set_pwm2_duty(pwm_r);
while(1);  // Prevent PIC from going to sleep.
Ringo42
PostPosted: Sun Jun 05, 2005 3:22 pm     Reply with quote
Thanks, Now I know it's a bad pin. I wrote a little program to just toggle all the pins and PIN_C1 never moves. Very stange.
Thanks for all the replies.
Ringo
Ringo Davis
Mark
PostPosted: Sun Jun 05, 2005 4:52 pm     Reply with quote
Ringo42 wrote:
I don't remeber the version but I bought it about 2 weeks ago. I have LVP in the fuses because that is how I program the chip. The chip is soldered down and I program it In-Circuit. I have the exact same code running on an 18f452 and it works fine. I'm going to try another chip at this point, I'm thinking it me be a bad pn or something.
Ringo
In-circuit doesn't mean LVP. Most in-circuit programmers still apply Vpp to program the chips. This includes the ICD's. What did you do with the LVP pin? Either RB3 or RB5 depending on whether we are talking about the 16F877 or 18F452.
Ringo42
PostPosted: Sun Jun 05, 2005 6:12 pm     Reply with quote
I pull the LVP pin down with a 10K resistor. I program the chip using a simple programmer that connects to the printer port. The programmer is powered by teh board being programmed so I only need 5V, not the 12 or 15 that a typical programmer uses. It costs me 1 I/O, but it is worth it because of the simpleness of teh programmer.
Ringo
Ringo Davis
PostPosted: Sun Jun 05, 2005 6:47 pm     Reply with quote
So you're probably using the TLVP or something similar to it.
http://www.finitesite.com/d3jsys/
Ringo42
PostPosted: Sun Jun 05, 2005 7:37 pm     Reply with quote
Same sort of thing. Mine uses a 74ls14 and 5 or 6 transistors. It works with several different software programs. I found the schematic online a couple years ago, but don't remeber where. Works great. If anyone needs a schematic let me know and I'll email it.
Ringo
Ringo Davis
