18F2455 Problems
imbue
PostPosted: Sun May 29, 2005 5:05 pm     Reply with quote
Can someone please explain this error message to me?
The Extended CPU Mode configuration bit is enabled, but the program that was loaded was not built using extended CPU instructions.
Whenever I compile the project in MPLAB IDE I get that error message, but when I compile in PCWH I don't.
Thanks.
imbue
PostPosted: Sun May 29, 2005 5:28 pm     Reply with quote
I changed the XINST fuse to NOXINST and now everything works perfectly. I would still be interested in why this is though, and why CCS makes XINST the default for a new project if it breaks eveything.
Thanks.
PostPosted: Sun May 29, 2005 6:42 pm     Reply with quote
Email CCS support about this and report the bug. Here's another
post where someone used the Wizard and had the same problem.
http://www.ccsinfo.com/forum/viewtopic.php?t=22707&highlight=noxinst
Their support email address is support@ccsinfo.com
Be sure to give them your compiler version.
imbue
PostPosted: Sun May 29, 2005 8:20 pm     Reply with quote
Alright, I emailed them.
