How to know if I'm using serial com?
Goto page 1, 2  Next
Marttyn
PostPosted: Thu Jan 30, 2020 3:42 am     Reply with quote
Thanks for your replies!
I want to know if #use RS232 was used, at compile time, not at runtime.
Lets imagine this:
int Add(int a, int b){
long result = a + b;
#ifdef RS232
   //only print this to COM port if its in use
   printf("%u + %u = %Lu", a, b, result);
   return (result);
So, when COM port is open, it will output the printf and also the internal result. But if its not, then only the result.
Of course, "RS232" is not a real define... (i think).
What i need is a define created by the compiler only when #use RS232 is used.
I could use this instead:
#define DEBUG
#ifdef DEBUG
#use rs232(uart1, baud=115200)
#ifdef DEBUG
   return (result);
But i just don't want to have extra defines, or additional coding. Just use the functions when i need them, without other worries.
There must be a way to find out if serial is open. Compiler should have some available define...
PostPosted: Thu Jan 30, 2020 4:15 am     Reply with quote
At the end of the day, just use a #define. That is what it is for...
Simple answer is 'no'. Reason is that the code does not exist at the
pre-compile stage where things like #if apply.
The compilation is a layered structure. The macro definitions and tests
are done _before_ the code is actually compiled, so at this point there
is no ability to test what is going to happen 'later' during the compile.
#USE RS232, is a compiler directive applied at compile time, not a
pre processor directive.
Marttyn
PostPosted: Thu Jan 30, 2020 4:28 am     Reply with quote
Make sense i guess...
I thought that while at precompile time, if "#use RS232" was found, maybe a #define was created, or some flag was set, that could be checked still at precompile time.
header.h
#define IM_USING_RS232
library.c
#ifdef IM_USING_RS232
   return (result);
Looks redundant to me.
PostPosted: Thu Jan 30, 2020 4:31 am     Reply with quote
You can go one step 'further':
Put a '#ifdef IM_USING_RS232' before the #use rs232, then you
only have to make the single change of defining this to automatically
add the #use rs232, and the code that uses it.
Marttyn
PostPosted: Thu Jan 30, 2020 4:38 am     Reply with quote
Keep in mind that my library is one for all. That means that, some programs use some of the included functions, and other programs use others.
When a program calls the add(a, b) function, this program may use, and others may not use the RS232.
So adding a extra #ifdef as you suggest, would just need additional changes to the main program, and its really not needed. As the program that is already using RS232 should not "not compile" that depending on the IM_USING_RS232 define.
PostPosted: Thu Jan 30, 2020 4:55 am     Reply with quote
I believe I found a way to do it.
Compile this code, with and without commenting the #use rs232() line.
Then look at the compiler build messages in the MPLAB output window.
You will get a warning message, and it will tell you if the #use rs232() line
is there or not. Also, in main(), it will put in printf() if #use rs232() is there.
#include <16F1847.h>
#fuses INTRC_IO, NOWDT, PUT, BROWNOUT
#use delay(clock=4M)
#use rs232(UART1, baud=9600, ERRORS)
// This will show it in the Build window at compile-time.
#if definedinc(RS232_ERRORS)
#warning We have RS232
#else
#warning We don't have it.
// This will put printf code into the program
// if the #use rs232() statement is there.
#if(definedinc(RS232_ERRORS))
printf("Hello there\n\r");
while(TRUE);
PostPosted: Thu Jan 30, 2020 5:02 am     Reply with quote
It will only work if you have 'errors' in your RS232 declaration. Now you
should always have this, but 'caveat'.
I had actually tried exactly this earlier, but on a PIC24, was not getting
the nice simple behaviour required.
PostPosted: Thu Jan 30, 2020 5:11 am     Reply with quote
I agree.
I made a refined version. This one acts like the O.P. actually wanted.
#define RS232 definedinc(RS232_ERRORS)
#if RS232
#warning We have serial.
#else
#if(RS232)
printf("Hello there\r");
while(TRUE);
Marttyn
PostPosted: Thu Jan 30, 2020 5:26 am     Reply with quote
Great! A nice approach!
But, to avoid to use ERRORS check this:
#if definedinc(STDOUT)
The first two simple test ive made worked fine... But dont know if it will work on all the circumstances...
PostPosted: Thu Jan 30, 2020 5:40 am     Reply with quote
I added your refinement and it works in this test program:
#define RS232 definedinc(STDOUT)
#if RS232
#else
#warning We don't have serial.
#if(RS232)
while(TRUE);
Marttyn
PostPosted: Thu Jan 30, 2020 6:05 am     Reply with quote
I don't understand this:
Benefits of define this instead of directly using it?
And also its not needed ERRORS:
Problem occur when a stream identifier is used:
#use rs232(UART1, baud=9600, stream=MY_COM)
PostPosted: Thu Jan 30, 2020 6:58 am     Reply with quote
Good.
However you should have ERRORS.
Basically ERRORS should always be used with a hardware UART, unless your
own code implements error checking. If you don't have it, the UART can
become hung. Treat it as something that should always be there.
In fact I'd prefer it is CCS made the default behaviour to have this, and
instead you had to use 'NOERRORS' if you did not want it. It'd be a better
implementation.....
PostPosted: Thu Jan 30, 2020 8:13 am     Reply with quote
I agree with Mr. T, put ERRORS in !
It saves a LOT of hair pulling wondering WHY doesn't it work now ? PIC, PC, USB dongle ???
It should be the default, then again, I think 'all digital I/O pins' should be default as that's all PICs had 3 decades ago.....
Smile
Marttyn
PostPosted: Thu Jan 30, 2020 9:32 am     Reply with quote
Noted! Put ERRORS in the #use RS232 Very Happy
Anyway, ive never found any problems with it. But next time could be "the one".
As said in previous post, checking for "STDOUT" works with default stream, but if using other stream ID, then this wont work Sad
PostPosted: Thu Jan 30, 2020 10:36 am     Reply with quote
Marttyn wrote:
I dont understand this:
In your post earlier in this topic, you showed an example using 'RS232'.
http://www.ccsinfo.com/forum/viewtopic.php?t=58490&start=5
I was just trying to give you what you wanted.
That's because if no stream is put in, the default stream is STDOUT.
You put in your own stream name of MY_COM. The CCS manual says:
putc() or putchar() or / fputc() - Puts a character over the transmit pin
(on the specified stream in the case of fputc, stdout by default).
and
If fprintf() is used then the specified stream is used where printf()
defaults to STDOUT (the last USE RS232).
Goto page 1, 2  Next
Page 1 of 2
