Problem with 10F200
PostPosted: Sun Apr 21, 2013 2:41 pm     Reply with quote
If you want pin GP2 (PIN_B2) to be an i/o pin, you need to clear the
T0CS bit in the OPTION register. See the example below:
#include <10F200.h>
#fuses NOWDT, NOMCLR
#use delay(clock=4M)
#define set_options(value)   {#ASM         \
                              MOVLW  value \
                              OPTION       \
                              #ENDASM}
set_options(0xDF);
PostPosted: Mon Apr 22, 2013 1:16 am     Reply with quote
The compiler does that for you, unless you have an old version.
.................... void main()
0002:  MOVLW  DF
0003:  OPTION
First two lines of the generated assembler.
The poster hasn't said what compiler version they have. I'd suspect a rather old one....
stoyanoff
PostPosted: Wed Apr 24, 2013 10:30 am     Reply with quote
My CCS is v4.134. Here is my schematic: http://dox.bg/files/dw?a=7b11e5b117
Do I have a mistake in it?
stinky
PostPosted: Thu Apr 25, 2013 8:58 am     Reply with quote
Try adding a 0.1uf decoupling capp to the VDD line of the pic?
I've been bit in the butt by that causing odd behavior.
Also, my compiler version doesn't support this part so I cannot confirm, but does
produce the desired setting? Your schematic doesn't show an external crystal so I'd assume you want the internal r/c setting.
PostPosted: Thu Apr 25, 2013 9:14 am     Reply with quote
The 10F20x chips _only_ operate with the internal oscillator. To save pins. Quote from data sheet:
"The PIC10F200/202/204/206 devices are offered with
Internal Oscillator mode only."
Makes oscillator selection rather easy!....
No possibility of an external crystal.
Agree wholeheartedly on the capacitor. Strange behaviours of all sorts can result if there is not adequate decoupling. Also don't think 'bigger is better' here, and say 'got 470uF on the supply'. Needs to be a capacitor with good HF performance (most electrolytic's do not have good HF perfromance), close to the chip.
