Posted: Sat Nov 26, 2011 3:42 pm |
I'm not at a location today where I can test this in hardware, or even with
the latest version, but try this code. I think it has a good chance to work.
#include <18F25K20.h>
#fuses H4,NOWDT,NOLVP,BROWNOUT,PUT,NOPBADEN
#use delay(clock=40M)
while(1) // Toggle LED at 1 Hz rate
output_toggle(PIN_B0);
FvM
Posted: Sat Nov 26, 2011 4:22 pm |
Quote: | try this code. I think it has a good chance to work. |
Yes. If you specify H4, you don't need (oscillator=10M,clock=40M) respectively (crystal=10M,clock=40M). The #delay syntax has been apparently intended as an alternative to explicite PLL fuses. Both methods work.
You may recognize an adavantage of the #use delay PLL specification when using a device that supports various clock multiply rates, not only fixed factor 4.
The problem is, that CCS abandoned once more a previously working syntax. |
mose
Posted: Sat Nov 26, 2011 5:41 pm |
@PCM programmer
Your code works.
I have tried the delay without either oscillator or crystal. But that just didn't make sense to me, that none was needed all of a sudden.
@FvM
You are right that since the PLL is fixed, they can very well come to the conclusion that all will be easier without oscillator / crystal in the delay line.
But I just prefer if CCS clearly state how their syntax is intended to work, especially when they change a working syntax to something new. - otherwise it hard to trust ones code to work properly under all conditions.
In general I just prefer to be sure, and when even the help file examples didnt work, I went for help...
Thanks for your help and answers. |
