Posted: Sun Mar 12, 2006 1:26 am |
One way to simplify it is to just cut out the options and the RS-232 stuff:
#include <16F877.h>
#device adc=8
#use delay(clock=10000000)
int8 value;
setup_ccp1(CCP_PWM);
setup_timer_2(T2_DIV_BY_4, 127, 1);
setup_port_a(ALL_ANALOG);
set_adc_channel(0);
value = read_adc();
set_pwm1_duty(value);
hongtao
Joined: 09 Mar 2006 Posts: 4 Location: Shanghai China
Posted: Wed Mar 15, 2006 5:26 am |
Hi
PCM programmer, thanks. It works. I can use it in my program.I find so
many post about PWM, after finishing my graduation project, I will write a
post to make a summary or a index, may be it will be easy to check.
谢谢!! |
