Humberto
Posted: Wed Jul 05, 2006 3:00 pm |
These are some of the abbreviation used by CCS and its meaning.
#FUSES PUT //Power Up Timer
#FUSES NOOSCSEN //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES WRT //Program Memory Write Protected
#FUSES WRTD //Data EEPROM write protected
#FUSES EBTR //Memory protected from table reads
#FUSES CPB //Boot Block Code Protected
#FUSES EBTRB //Boot block protected from table reads
#FUSES WRTC //configuration registers write protected
#FUSES WRTB //Boot block write protected
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
But always the reference is the Microchip Datasheet as PCM Programmer stated, it is your job to understand
and "translate" each achronism.
Humberto
1. Edited
to ADD more FUSES defenitions
