Posted: Tue Aug 23, 2005 2:40 pm |
The following program will blink the LED labeled "RB0" on the PicDem2-
Plus board. Make sure jumper J6 is installed (it's next to the LEDs).
Also note that since the PicDem2-Plus board has an oscillator and
not a crystal, you need to use the EC_IO fuse instead of XT.
Also, in MPLAB vs. 7.20, after you program the PIC, you can release
the board from reset by clicking the button on the MPLAB menu bar
that has an upwards transition symbol on it. Then the LED will start
blinking. Or, you could just unplug the ICD2 cable from the board.
| Code: | #include <16F628A.H>
#fuses EC_IO, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
output_high(PIN_B0);
output_low(PIN_B0);
Posted: Tue Aug 23, 2005 2:56 pm |
Thanks..
I got it now, even those the config drop down list state that 16f628a
upport debug, but it is not true. It only support as a programmer when use the ICD2.
On demo 2 plus board, have to use the fuse EC.
Thanks again.... |
Posted: Tue Aug 23, 2005 3:15 pm |
If you want debugging capability, go to the 16F88. It's the same package
size, but it can be debugged with ICD2. I tested it just now with the
PicDem2-Plus board and it works with ICD2 in debug mode and in
programmer mode. Here is the test program:
| Code: | #include <16F88.h>
#fuses EC_IO,NOWDT,NOPROTECT,PUT,BROWNOUT,NOLVP
output_low(PIN_B0);
MikeValencia
Posted: Tue Aug 23, 2005 4:04 pm |
Looks like the question has been solved.
I also had the same problem with the PIC16LF627. Debugging gave an invalid device error, but setting up the icd-2 as a programmer gave no problems.
-Mike |
