Posted: Fri Jul 16, 2004 6:29 pm |
You may have to do as Neutone suggests, and help the compiler
to allocate ram properly by using the #locate directive for your
large arrays. This appears to work. (ie., it now compiles without
an "out of ram" error). Example:
node nodes1[24];
#locate nodes1 = 0x110
node nodes2[24];
#locate nodes2 = 0x190 |
Darren Rook
Joined: 06 Sep 2003 Posts: 287 Location: Milwaukee, WI
Posted: Fri Jul 16, 2004 6:34 pm |
| Maybe I didn't understand your problem, but why do you care where stuff is in RAM? That is why you buy a compiler, to handle placing things in RAM and for you to not worry about it. |
Royce
Posted: Fri Jul 16, 2004 7:21 pm |
Darren: the compiler was failing to compile this code. Its not that I care where the variables are, but they do have to be somewhere. Before I made the change that PCM Programmer made the compiler simply wasn't allocateing the space. Plus it was putting a bunch of variables ontop of one another at location zero.. which is a bad place for them to be.
PCM Programmer: Thanks a bunch for the work around! My symbol table looks sane now. I guess I'm kind of dissapointed that the compiler could not figure it out by itself. And it strikes me a strange that telling the compiler to put those arrays in the same place it was automatically selecting without the #locates would somehow allow it to find homes for all the other variables.
Would you not count that a compiler bug? Should I turn in a bug report?
All in all though this still looks to be a good upgrade from CC5X. Those expressions were killing me,
Thanks again,
Royce |
Alex Guest
Posted: Mon Oct 04, 2004 8:45 am |
| Don't you have to switch between banks when you use the #locate in different banks ? |
Posted: Mon Oct 04, 2004 1:34 pm |
| Quote: | Don't you have to switch between banks when you use the
No. The compiler knows which banks the variables are in, because
the upper bits of the address are specified in the address that you
use with the #locate statement.
One of the features of the CCS compiler is that you don't have to
manually put in bank switching code. It knows what bank everything
is in, and automatically puts in code to switch to the correct bank
before accessing a variable.
Edited to add:
I just noticed you asked this question (and got an answer) in another
thread, here:
http://www.ccsinfo.com/forum/viewtopic.php?t=20605
You should only ask a question in one thread. Don't tack the same
question onto several threads. |
C-H Wu Guest
| don't push it to the limit |
Posted: Mon Oct 04, 2004 7:43 pm |
| Royce wrote: | Darren: the compiler was failing to compile this code. Its not that I care where the variables are, but they do have to be somewhere. Before I made the change that PCM Programmer made the compiler simply wasn't allocateing the space. Plus it was putting a bunch of variables ontop of one another at location zero.. which is a bad place for them to be.
Thanks again,
Royce |
I compiled your code, happy with nodes1[20], cried out with nodes1[24].
You should file a bug report, although I would call it a compiler 'defect' instead of 'bug'.
The problem is CCS always put 'local' variables at the 'end' of available RAM.
In your case, you need two 96-byte array, which have to filled up bank 2 and 3, then, there is no more RAM after bank 3, as a result, CCS cried out.
The easiest way to get around, is to reduce you array size. say, instead of 96-bytes array, 80-bytes array will be much more easier for CCS to handle, since all 4 banks has at least 80 byte space.
node nodes1[20]; // instead of 24, thus, 80 bytes instead of 96
node nodes2[20];
can you live with 20 ?
last words, don't push it to the limit
Best wishes |
