Posted: Tue Mar 12, 2013 11:14 am |
If the drop down box at the top of MPLAB doesn't show DEBUG or
RELEASE, it means you need to re-install the CCS plugin.
Here is the link for the MPLAB 8.xx plugin:
http://www.ccsinfo.com/downloads/setup_mplab_plugin.exe
When you create a new project in MPLAB 8.xx, the drop-down box will
be set for DEBUG by default. To change this behavior for new projects,
and to make it default to RELEASE mode, edit the Windows registry
per the instructions in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=46818&start=21
If you still have problems with BROWNOUT and other fuses being disabled,
even though you removed the #fuses DEBUG line, it means you likely
have #device ICD=TRUE in your program. Comment out that line. |
ttime
FIXED |
Posted: Wed Mar 13, 2013 1:56 am |
Yeah, man, that's it!! THANKS!!!!! |
