16F1823 UART Problems
PostPosted: Tue Mar 27, 2012 5:45 pm     Reply with quote
I tested the following program with vs. 4.130 in hardware and it works OK.
(It doesn't work if I specifiy UART1 instead of the pin numbers).
With vs. 4.128, the compiler always generates a software UART
if I specify the pins, or if I specify UART1.
#include <16F1823.H>
#fuses INTRC_IO, NOWDT, NOMCLR
#use delay(clock=32M)
#use rs232(baud=9600, xmit=PIN_A0, rcv=PIN_A1, errors)
#int_rda
void rda_isr(void)
char c;
c = getc();
putc(c);
enable_interrupts(INT_RDA);
curt2go
PostPosted: Tue Mar 27, 2012 5:58 pm     Reply with quote
I stuck in my output_high(pin_a2); in the INT and its not working. Do I need version 4.130? to use the interrupt? I used your code. SO either my board is whacked or ? was your comms pic to pic that you tested? Thanx for the help..
PostPosted: Tue Mar 27, 2012 9:37 pm     Reply with quote
The rs232 was between the 16F1823 and my PC. I used TeraTerm as
the terminal program. The 16F1823 was installed in a Microchip "Low Pin
Count" board. I used a Sparkfun Level Shifter to convert the TTL voltage
levels from the PIC to rs232 levels:
http://www.sparkfun.com/products/449
If you can get vs. 4.130, then it should solve your problem.
gpsmikey
PostPosted: Tue Mar 27, 2012 9:45 pm     Reply with quote
Note that according to an email I got today, 4.131 of the compiler is now out.
mikey
mikey
old engineering saying: 1+1 = 3 for sufficiently large values of 1 or small values of 3
curt2go
PostPosted: Tue Mar 27, 2012 10:17 pm     Reply with quote
Bought the update. Mine ran out in Jan. $275 for a bug. Smile If it works then I will be happy. I will post tomorrow the results.
I do wish when you order the updates that you can get them right away instead of waiting for CCS to manually enter stuff. But I digress.
curt2go
PostPosted: Wed Mar 28, 2012 10:59 am     Reply with quote
Works good with 4.131.... It was the compiler... But it works so I am very happy.. Thanx for everyones help..
