what to do, I can't understand
PostPosted: Fri Oct 07, 2011 2:48 pm     Reply with quote
OK, then the first thing you need to do is to fix this:
#int_timer0
int16 p,q;
timer0_isr()
p++;
q++;
You can't put anything between the #int_xxxx statment and the isr
function. If you do that, the isr code will not be compiled (and the
compiler will not tell you this). You can see this in the .LST file, shown
below. Notice there is no ASM code generated:
.................... #int_timer0
.................... int16 p,q;
....................  timer0_isr()
.................... p++;
.................... q++;
.................... void main()
This is the correct way:
int16 p,q;
#int_timer0
timer0_isr()
p++;
q++;
Compile it as above, and notice that you now get ASM code generated:
0037:  INCF   28,F
0038:  BTFSC  003.2
0039:  INCF   p+1,F
003A:  INCF   2A,F
003B:  BTFSC  003.2
003C:  INCF   q+1,F
003D:  BCF    00B.2
003E:  BCF    00A.3
003F:  BCF    00A.4
0040:  GOTO   01B
So you need to fix that part of your program, and then you can continue
with the program development.
freedom
PostPosted: Sat Oct 08, 2011 7:53 am     Reply with quote
Dear PCM programmer
Thanks a lot for your kind help and guideline.
I start to learn c by this book "Programming 8-bit PIC Microcontrollers in C
by Martin P.Bates".
Do you have have any good suggestion on book/tutorial for the beginner like me please help.
If so, please provide me some link.
Thank you once again.
PostPosted: Sat Oct 08, 2011 11:59 am     Reply with quote
Here are some threads on books:
http://www.ccsinfo.com/forum/viewtopic.php?t=27839
http://www.ccsinfo.com/forum/viewtopic.php?t=33272
This post has many links to online tutorials on C and CCS and PICs:
http://www.ccsinfo.com/forum/viewtopic.php?t=46384&start=3
freedom
PostPosted: Sun Oct 09, 2011 5:50 am     Reply with quote
thanks a lot
freedom
PostPosted: Sun Oct 09, 2011 8:35 am     Reply with quote
Now the code is working but I suspect a problem while I simulate it with Proteus 7.7.
I suspect timing is not accurate as I want to do start the timer at the point that is noted in the code.
what to do:
#include <16F877A.H>
#use delay(clock = 4000000)
#include <flex_LCD420.c>
int16 p,q;
#int_timer0
 timer0_isr()
p++;
q++;
   setup_timer_0(RTCC_INTERNAL|RTCC_8_BIT|RTCC_DIV_4);
   enable_interrupts (INT_TIMER0);
   enable_interrupts(global);
   set_timer0(6);
// Clear the LCD.
printf(lcd_putc, "\f");
delay_ms(50);
   printf(lcd_putc, "\f  PIC Experiment");
   printf(lcd_putc, "\n--------------------");
   printf(lcd_putc, "\nNice Day ");
   if (!input(pin_D0))    // switch 1
   {output_high(pin_C0);} // I want to start the timer at this point
   if (p==1000)
   {output_low(pin_C0);
   p=0;}
   if (!input(pin_D1))        // switch 2
   {output_high(pin_C1);}   // I want to start the timer at this point
  if (q==500)
   {output_low(pin_C1);
  q=0;}
PostPosted: Sun Oct 09, 2011 9:49 am     Reply with quote
You have two and only Two options.
1) Hack into Proteus and FIX one of the many bugs and errors that it has....
2) Get RID of PROTEUS and use real hardware !
I suspect that option #2 is your only choice.
freedom
PostPosted: Sun Oct 09, 2011 1:55 pm     Reply with quote
Thanks temtronic
Actually I suspect there is a bug in my code not in Proteus.
Anyway, in my code is it really timing accurately as per my desire .
Maybe I mistake something.
PostPosted: Sun Oct 09, 2011 5:20 pm     Reply with quote
My advice is to make a more simple program. Just use one button and
one LED. Get that working reliably. Then add more features later.
FvM
PostPosted: Mon Oct 10, 2011 12:29 am     Reply with quote
But you don't. Starting the timer would involve resetting the timer variable.
freedom
PostPosted: Mon Oct 10, 2011 3:42 am     Reply with quote
Many thanks FvM for your valued suggestion.
You are right.
Now its working.
