Posted: Fri Jun 19, 2009 5:04 pm |
I created the Vref voltages with a voltage divider made from 3 resistors,
and I connected it to the PIC as shown below.
2.2K 2.0K 820 ohms
+5v ---/\/\/\/---o---/\/\/\/---o---/\/\/\/--- Ground
2.8v 0.8v
To pin RA3 To pin RA2
Vref+ Vref-
I have a 5K trimpot connected to pin A0 to provide the input analog
voltage. If I set the trimpot to 2.82v, I get this output from the program
below. (The compiler is doing the A/D conversions in 8-bit mode).
Quote: | 254
254
254
254
254 |
If I set the voltage on pin A0 to 0.83 volts, I get the following output:
Those readings are correct, for the given Vref circuit. This was tested
with vs. 4.093 of the compiler, on a PicDem2-Plus board.
Here is the test program:
#include <16F877A.H>
int8 result;
setup_adc_ports(AN0_VREF_VREF);
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
delay_us(20);
result = read_adc();
printf("%u \n\r", result);
