Posted: Fri Feb 23, 2007 5:54 pm |
I ran your program (shown below) on a PicDem2-Plus and I got this:
Quote: |
61622
63899
63899
63899
63899
63899
63900
63900
63900
63899
Code: | #include <16F877A.H>
int16 k;
int8 i;
for(i = 0; i < 10; i++)
setup_timer_1(T1_DISABLED);
set_timer1(32768);
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1|T1_CLK_OUT);
delay_ms(950);
k = get_timer1();
printf("%lu\n\r", k);
Imanjl
Posted: Sat Feb 24, 2007 2:59 am |
rnielsen wrote: | If you need accurate timing then you will need to allow the timer to roll over, causing an interrupt, and have that flag whatever you want done. |
I wrote a new program without using get_timer1(); at this time when timer overflows(1s) it generates an interrupt .but still 1 second isnt accurate . This program generates 1 second in about 850-950mS .
Code: | #int_TIMER1
TIMER1_isr(){
set_timer1(32768);
count++;}
{int16 k;
int8 i;
set_timer1(32766);
loop:
printf("\ntimer1=%lu\n\r",count);
goto loop ;} |
hi pcm programmer ,ur result shows that the program works fine on Picdem2 cause (63900-32768)*30.5us=949ms .Maybe there is something wrong with my hardware according to microchip refrence manual,32.768 need two 33pf capacitors I use 30pf for c1 and c2 but I dont think it affects the result so much ,whats the Picdem2 caps value for timer1 ?
Besides the pic is on the bread board :
Quote: | Design Tips
2. You should ensure the your layout uses good PCB layout techniques so that noise does not couple onto the Timer1 oscillator lines. |
