murtis
Posted: Wed Aug 06, 2008 9:10 am |
I tried to use the memory of the microcontroller. And, i saw that it needs to time very much for one dot on glcd screen. So, we need to use memory of the glcd that is very bg problem... _________________ MurtiS |
sliders_alpha
Posted: Thu Jun 18, 2009 5:14 am |
hi
I've just tied these with a RA8835 and whatever I do after the init, my screen is just displaying random pixel, some are on some are off.
I don't think it's a wiring error since if I do (on purpose) a wiring error my screen is displaying vertical line.
I have just modified the SED1335.C for my application. Data were put on a full port, I'm putting them on separate pins like this :
To place data on the bus
output_bit(LCD_DB0, !!(data & 1));
output_bit(LCD_DB1, !!(data & 2));
output_bit(LCD_DB2, !!(data & 4));
output_bit(LCD_DB3, !!(data & 8));
output_bit(LCD_DB4, !!(data & 16));
output_bit(LCD_DB5, !!(data & 32));
output_bit(LCD_DB6, !!(data & 64));
output_bit(LCD_DB7, !!(data & 128));
and reading them, like this :
int8 glcd_readByte()
to read data from the bus
data = input(LCD_DB0) + data;
data = input(LCD_DB1)*2 + data;
data = input(LCD_DB2)*4 + data;
data = input(LCD_DB3)*8 + data;
data = input(LCD_DB4)*16 + data;
data = input(LCD_DB5)*32 + data;
data = input(LCD_DB6)*64 + data;
data = input(LCD_DB7)*128 + data;
Here is my code :
#include <16F876A.H>
#use delay(clock = 20000000)
#include <sed1335_for_me.c>
#include <graphics.c>
glcd_init(ON);
delay_ms(250);
// glcd_fillScreen(ON);
glcd_fillScreenText('A');
I'm using A0,A1,A2,A3,A5,C3,C4,B0-B5.
Any idea?
thanks _________________ yup, i know, i don't speak english very well
CCS V4.057 |
sliders_alpha
Posted: Fri Jun 19, 2009 2:05 am |
so, a demo board was given with my screen, and i've notice that you can solder on it a 6pin connecter to allow re-programming of it's 16F57
so now, faulty wiring is impossible.
here i've took two pictures, the first is the LCD initialised with nothing done
the second it the lcd initialised with an fillscreen(on) done
the upper part did not change, it's because i used a 2$ camera and moved a little
the upper part is made of random pixel and the lower part of random character
my code :
#include <16F57.H>
#fuses RC, NOWDT, NOPROTECT
#use delay(clock = 5200000)
#define LARGE_LCD 1
#include <SED1335.C>
glcd_init(on);
glcd_fillScreen(1);
i'm using this screen
CCS V4.057
and those pin :
data port : port C
RST PIN_B0
RD PIN_A1
WR PIN_A0
CS PIN_A2
A0 PIN_A3 _________________ yup, i know, i don't speak english very well
CCS V4.057 |
repepon
Posted: Fri Feb 19, 2010 7:21 am |
Hi, I know its been a while but I am having the same problem with the source code.
The problem is the reading byte from the LCD memory display not the pixel write.
Has anyone solved it? Has anyone have correct a reading routine?
Thanks! |
josi2257
Posted: Wed Dec 01, 2010 8:53 pm |
Hello!
First of all, I'm sorry for my english. I can see that this post is very old, but perhaps I've made something that may help someone.
I've found the library for the RA8835 Controller that "sliders_alpha" did, and I tried to use it with my GLCD. I found the code in "RA8835 drivers for 320x240 LCD":
http://www.ccsinfo.com/forum/viewtopic.php?t=39353
My LCD model is: WG-320240-C0-TFH (with RA8835).
I spend so many days trying to make it work, and I had the same problem that "murdis", that mistake on the reading cycle. I realized today that my LCD was in "6800 mode", by measuring the pins SEL1 y SEL2 from the RA8835 chip (you can see the location of these pins in the datasheet of RA8835). The code is written for "8080 mode". However, it works the same way for the writing cycle, but is different for the reading cycle.
In my LCD board, the pin 53 (SEL1) had 5V and the pin 52 (SEL2) had ground.
So I've modified sliders_alpha's code for using with the LCD in "6800 mode". It doesn't change too much, but, as you could see, a little character of your code can always make the difference. The change is to use the ENABLE_CLOCK pin instead of the READ pin, and use the WRITE pin as a READ/WRITE pin (it's all in the datasheets). Besides I wrote some lines for the correct reading of the data bus (you can see this in the glcd_pixel routine). I have this routine working right in my GLCD. I use a PIC18F4550, with 48MHz of clock frecuency (look out the delays). The pins between the LCD and the PIC were also changed, you can choose were you want them and change them in the begining of the code.
I hope it's useful for someone, because I've seen that many people had the same problem than me (reading corrupted data), and it's very possible that the problem was the "6800 mode".
I always find solutions in this forum, and today is the first time that I (try to) give solutions. I'm glad... Thank you for everything!
// "sliders_alpha" original file
// Modified for working with the "6800 mode"
#ifdef DELAYS_48MHZ
#define delay_xt 5
#ifdef DELAYS_20MHZ
#define delay_xt 1
#define GLCD_RW PIN_A0 // Changes
#define GLCD_E PIN_A1 // Changes
#define GLCD_CS PIN_A2
#define GLCD_A0 PIN_A3
#define GLCD_RST PIN_A4
#DEFINE GLCD_DB0 PIN_D0
#DEFINE GLCD_DB1 PIN_D1
#DEFINE GLCD_DB2 PIN_D2
#DEFINE GLCD_DB3 PIN_D3
#DEFINE GLCD_DB4 PIN_D4
#DEFINE GLCD_DB5 PIN_D5
#DEFINE GLCD_DB6 PIN_D6
#DEFINE GLCD_DB7 PIN_D7
#define GLCD_WIDTH 320
#define GLCD_HEIGHT 240
#define GLCD_CHAR_WIDTH 8
#define GLCD_CHAR_HEIGHT 8
#define ON 1
#define OFF 0
#define COMMAND_MODE output_high(GLCD_A0);
#define DATA_MODE output_low(GLCD_A0);
#DEFINE RA8835_GRAPHICSTART 0x2580
void GlcdPutData(INT8 data);
int8 TakeData(void);
void GLCD_WriteCommand(int8 commandToWrite);
void GLCD_WriteData(int8 dataToWrite);
int8 GLCD_ReadData(void);
void setCursorAddress(int16 addr);
void GlcdGotoTextXY(int16 x, int16 y);
void GlcdPutC(char c);
void FillText(char cara);
void FillGraphic(int1 parameter);
void glcd_RAinit(void);
int8 GLCD_ReadStatus(void);
void GlcdPutData(int8 data)
output_bit(GLCD_DB0, bit_test(data,0));
output_bit(GLCD_DB1, bit_test(data,1));
output_bit(GLCD_DB2, bit_test(data,2));
output_bit(GLCD_DB3, bit_test(data,3));
output_bit(GLCD_DB4, bit_test(data,4));
output_bit(GLCD_DB5, bit_test(data,5));
output_bit(GLCD_DB6, bit_test(data,6));
output_bit(GLCD_DB7, bit_test(data,7));
int8 TakeData(VOID)
INT8 data = 0;
data += input (GLCD_DB0);
data += input (GLCD_DB1) * 2;
data += input (GLCD_DB2) * 4;
data += input (GLCD_DB3) * 8;
data += input (GLCD_DB4) * 16;
data += input (GLCD_DB5) * 32;
data += input (GLCD_DB6) * 64;
data += input (GLCD_DB7) * 128;
RETURN data;
void GLCD_WriteCommand(int8 commandToWrite) // Changes
GlcdPutData(commandToWrite);
output_low(GLCD_E);
COMMAND_MODE
output_low(GLCD_RW);
output_low(GLCD_CS);
delay_cycles(delay_xt);
output_high(GLCD_E);
output_low(GLCD_E);
output_high(GLCD_RW);
output_high(GLCD_CS);
void GLCD_WriteData(int8 dataToWrite) // Changes
GlcdPutData(dataToWrite);
output_low(GLCD_E);
DATA_MODE
output_low(GLCD_E);
int8 GLCD_ReadData(void) // Changes
int8 tmp;
output_low(GLCD_E);
tmp = TakeData();
output_low(GLCD_E);
return tmp;
output_high(GLCD_RST);
//system set
GLCD_WriteCommand(0x40);
GLCD_WriteData(0x30);
GLCD_WriteData(0x87);
GLCD_WriteData(0x07);
GLCD_WriteData(0x27);
GLCD_WriteData(0x2F);
GLCD_WriteData(0xEF);
GLCD_WriteData(0x28);
GLCD_WriteData(0x00);
//scroll
GLCD_WriteCommand(0x44);
GLCD_WriteData(0xF0);
GLCD_WriteData(0x80);
GLCD_WriteData(0x25);
GLCD_WriteData(0x4B);
//HDOT SCR
GLCD_WriteCommand(0x5A);
//OVLAY
GLCD_WriteCommand(0x5B);
GLCD_WriteData(0x01);
//erase all screen
FillGraphic(OFF);
FillText(' ');
//DISP ON
GLCD_WriteCommand(0x58);
GLCD_WriteData(0x56);
//CSRFORM
GLCD_WriteCommand(0x5D);
GLCD_WriteData(0x04);
GLCD_WriteData(0x86);
//DISP ON
GLCD_WriteCommand(0x59);
//CSDIR
GLCD_WriteCommand(0x4C);
//CSRW
setCursorAddress(0x0000);
long count;
//set cursor to 2580h
setCursorAddress(0x2580);
//put 00h in all graphic space
count = 9600;
GLCD_WriteCommand(0x42);
while(count != 0)
GLCD_WriteData(0xFF * parameter);
count--;
long count;
//set cursor to 0000h
//put 00h in all text space
count = 1200;
while(count != 0)
GLCD_WriteData(cara);
count--;
GLCD_WriteData(c);
//x and y : 1 to max
int16 adress = 0;
adress = (y-1)*40;
adress = adress+ x-1;
setCursorAddress(adress);
int8 adress;
GLCD_WriteCommand(0x46);
adress = addr & 0xFF;
GLCD_WriteData(adress);
adress = addr >> 8;
void GLCD_Pixel(int16 x,int16 y, int1 color)
int8 tmp = 0;
int16 address = 0;
address = RA8835_GRAPHICSTART + (40 * y) + (x/8);
setCursorAddress(address);
GLCD_WriteCommand(0x43);
GLCDPutData(0x00);
set_tris_d(0xFF); // Set the Port D as inputs before I call
// GLCD_ReadData; it doesn't work
// without this line.
// The rest is the same.
tmp = GLCD_ReadData();
set_tris_d(0x00); // Port D as outputs again.
if(color == ON)
tmp |= (1 << (7 - (x % 8)));
tmp &= ~(1 << (7 - (x % 8)));
GLCD_WriteData(tmp);
void GLCD_GraphicGoTo(int16 x,int16 y)
setCursorAddress(RA8835_GRAPHICSTART + (y * 40) + x/8);
int8 tmp;
output_low(GLCD_E);
tmp = takedata();
output_low(GLCD_E);
return tmp;
_________________ Josi |
