ryoung Guest
| Re: urgent please (Microchip SPI A/D MCP3202) |
Posted: Thu Aug 21, 2003 2:56 pm |
I have modified some of the routines from the CCS examples for another project and they work OK with PIC16F877A and PIC16F73s
I've used this at 4MHz and 20MHz with xtals and ceramic resinators (all for combinatinos).
I have fast_io enabled for all my I/O lines.
Rob Young
rwyoung@ieee.org
* int16 read_mcp3202(int8 channel)
* Purpose : Sample data from 2 channel ADC. ADC is 12-bits, unipolar.
* Parameters : channel - 1 or 2
* Calls : write_spi_byte()
* read_spi()
* Returns : Value read from ADC. Return data is LSB justified in 16 bits
* Notes :
* Tested : 02/03 RWY
int8 ctrl_bits;
int8 high;
int8 low;
output_low(SPI_CLK);
output_high(SPI_DIN);
output_low(ADC_CS);
if (channel==1)
ctrl_bits = 0b00001011; // channel 1 single ended
ctrl_bits = 0b00001111; // channel 2 single ended
write_spi_byte(ctrl_bits, 5); // send control bits (4 bits plus dummy clock)
high = read_spi(4);
low = read_spi(8);
output_high(ADC_CS);
return ( make16(high,low));
* void write_spi_byte(int8 data, int8 num_bits)
* Purpose : Write upto 8 bits of data to SPI device. SPI device chip select
* must be activated prior to calling this subroutine.
* Parameters : data - data to write
* num_bits - up to 8 bits
* Calls :
* Returns : none
* Notes :
int8 i;
delay_us(1);
for(i=0;i<num_bits;i++)
if ((data & 1) == 0)
output_low(SPI_DIN);
data = data >> 1;
delay_us(1);
output_high(SPI_CLK);
delay_us(1);
* int8 read_spi(int8 num_bits)
* Purpose : Read upto 8 bits of data from SPI device. SPI device chip
* select must be activated prior to calling this subroutine.
* Parameters : num_bits - up to 8 bits
* Calls :
* Returns : data read from SPI device.
* Notes :
int8 i;
int8 data;
data=0;
for(i=0; i<num_bits; i++)
delay_us(1);
shift_left(&data,1,input(SPI_DOUT));
delay_us(1);
return (data);
Original Post ID: 144517139 |
