Posted: Mon Jan 21, 2008 12:28 pm |
Here is an example of how to send an array of bytes:
Code: | #include <16F877.H>
#define HEAD 0x03
#define TAIL 0x95
int8 data[] = {0x55, 0x56, 0x57, 0x58};
int8 i;
putc(HEAD);
for(i = 0; i < sizeof(data); i++)
putc(data[i]);
putc(TAIL);
John P
Posted: Mon Jan 21, 2008 2:23 pm |
One tip that might be useful.
If you have to send arbitrary data, you can get situations where a data element has the same value as your HEAD byte. A way to deal with this is to say that any time this happens, you will send the same element again. That means that if the receiving end of your link encounters a HEAD byte that isn't immediately repeated, it can assume that it's the start of a new packet. This helps keep packets straight if (for instance) there are occasional breaks in the transmission line, or units getting turned off and on.
But if you know ahead of time what's going to be sent, perhaps it's certain that the HEAD byte represents itself and nothing else. In that case, no problem. |
shen Guest
Posted: Mon Jan 21, 2008 8:45 pm |
I understand a little, I try it again, Thank you |
umka
Posted: Sun Mar 23, 2008 8:14 pm |
Can one have an array of variables? or can one change a single byte in an array without having to update the whole array?
can one use for example data[2] = 0x25; to change just the second number in the array to 0x25.
I want to send an array through RS232 to show button states, each byte will represent 8 buttons. |
Douglas Kennedy
Posted: Mon Mar 24, 2008 4:21 am |
There are many ways to learn. The most successful is often to learn by doing. It involves experimenting. The PIC environment allows both simulation and debugging. You could have used the simulator and assigned the array element and discovered that it would work. This has advantages since it strengthens confidence and self reliance and allows a programmer to discover his/her own errors. As code grows more complex and lengthy fewer people are willing to spend time discovering another's errors so self reliance becomes necessary. Help for a vexing problem can still be needed and in that case for a speedy response code must be trimmed down to a dozen lines that
exhibit the problem. The value to this is that often times the act of trimming it down makes the issue obvious to the very programmer with the issue. |
huutanbkpic
Someone please help me? |
Posted: Sun Apr 13, 2008 2:59 am |
I would like to send the percentage of PWM module from PC to PIC, but i do not know how to send the floating-point number over RS232 please help me!
For example: can anyone provide me a code to send 78.05 from PC in visual C++ and the code for the int_rda to receive the data.
Best regards. _________________ Thanks for your attention |
KU5D
Joined: 10 Feb 2008 Posts: 46 Location: Asheville, North Carolina
Posted: Sun Apr 13, 2008 9:53 am |
Perhaps multiply your 78.05 x 100 in the PC and send it as two bytes (7805). When the PIC receives it, stick it in an array. If you're printing this for a user you can use formatting to display the MSB to the left of the decimal point, and the LSB to the right. Better than dealing with floats. _________________ Confidence is the feeling you have right before you fully understand the situation... |
Douglas Kennedy
Posted: Sun Apr 13, 2008 10:46 am |
Floating point notation has many forms. The CCS form is described in the CCS manual. I will assume here you are using the 4 byte notation of CCS.
This means if this 4 bytes of notation is sent across a RS232 interface the notation when successfully received will still be just CCS notation. Now the PC program has to be able to understand this notation. If you search this forum you will find solutions to your issue of compatability of CCS notation with PC software notation. Expect to learn about unions to map the CCS notation to a 4 byte array so the bytes of notation can be individually transmitted. Expect to learn about how the various PC software programs use their specific floating pt notation. Now a way out is to let the PIC via a printf statement convert the internal floating pt notation to ascii char notation for the number. Expect to learn about printf formatting. At the PC end most software accepts ascii notation for numbers Ex "1234.5678901" and will convert from that notation to its specific float notation. |
