dual i2c on 8722
PostPosted: Thu Feb 22, 2007 2:09 am     Reply with quote
You could write a substitute routine for the bad library code. Only the
i2c_write() function has a problem and only in the 2nd SSP module.
One easy way to do this is to look at the ASM code in the .LST file
and write C code that does the same thing. I've done this below.
Here's the corrected ASM code for the i2c_write() function for the 2nd
i2c port on the 18F8722. I've fixed the register address and bit position
for the SSP2IF bit, and I've added comments:
... #use i2c(master, sda=PIN_D5, SCL=PIN_D6, FORCE_HW)
00004:  BCF    F63.7   // Set WCOL2 = 0
00006:  BCF    FA4.7   // Set SSP2IF = 0
00008:  MOVFF  07,F66  // Put byte into SSP2BUF
0000C:  MOVLW  02
0000E:  BTFSC  F63.7   // Test WCOL2
00010:  BRA    001C    // Return 2 if WCOL2 = 1.
00012:  BTFSS  FA4.7   // Test SSP2IF
00014:  BRA    0012    // Wait in loop if SSP2IF = 0
00016:  MOVLW  00
00018:  BTFSC  F62.6   // Test ACKSTAT
0001A:  MOVLW  01      // Return state of ACKSTAT
0001C:  MOVWF  01
Here's a functional translation of the above ASM code to C. It doesn't
compile to exactly the same ASM code, but it performs the same functions.
// Define registers and bits used by the routine.
#byte SSP2CON1 = 0xF63
#bit  WCOL2 = SSP2CON1.7
#byte PIR3 = 0xFA4
#bit  SSP2IF = PIR3.7
#byte SSP2CON2 = 0xF62
#bit  ACKSTAT2 = SSP2CON2.6
#byte SSP2BUF = 0xF66
// Here is the new routine.  Call it instead of i2c_write()
// in the CCS library code for the 2nd SSP module.
int8 i2c_write_ssp2(int8 value)
int8 retval;
WCOL2 = 0;
SSP2IF = 0;
SSP2BUF = value;
if(WCOL2)
   retval = 2;
   while(!SSP2IF);
   retval = ACKSTAT2;
return(retval);
