Posted: Sun Feb 11, 2007 5:25 pm |
I made a small test program, using the Flex LCD driver, and tested it
with three brands of 8x2 LCDs. It worked with all of them.
Here are the 8x2 LCDs:
1. CrystalFontz CFAH0802A-NYA-JP
2. Hantronix HDM08216H-3-S00S
3. Fema CM0823-SYR1 (Note: obsolete -- replaced by CM0826)
Here's the test program:
#include <16F877.H>
#fuses XT,NOWDT,PUT,BROWNOUT,NOLVP
#include "Flex_LCD.c"
lcd_putc("Hello 1\n");
lcd_putc("World 2");
| Quote: |
I have r/w tied to ground for a 6-wire interface. This did work with picbasic. Does CCS have any dificulty with this? |
It's not a CCS issue, it's the Flex LCD driver. It has to be configured
to work with a 6-pin interface. This is done by commenting out the
following line in the Flex_LCD.c file:
| Code: | | // #define USE_RW_PIN 1 |
If that line is commented out, the Flex driver will be configured to work
with a 6-pin interface. I tested it this way, and it worked.
I suggest that you use the Flex LCD driver from the CCS code library.
Don't edit it, except to change the pin numbers to fit your board, and to
comment out the "#define USE_RW_PIN 1" statement. |
Posted: Mon Feb 12, 2007 3:57 am |
Hi PCM Programmer
Yes this does work! I just changed the device to the "a" type and the pin settings in the flex lcd driver, and voila!
So I tried to figure out why it doesn't work in the main program. Finally I have a display now, but don't really know why. I commented out the following fuses
#FUSES NOPROTECT
#FUSES NODEBUG
#FUSES NOCPD
#FUSES NOWRT
and
#device ICD=TRUE
and changed
#FUSES NOBROWNOUT to #FUSES BROWNOUT
These had all been set by the project wizard.
Now I will further debug the code to make sure there's not only some text displayed but the one there should be...
Thanks a lot for this help for the moment, chances are good that I'll come back with further questions.
Regards
Martin |
kender
Joined: 09 Aug 2004 Posts: 768 Location: Silicon Valley
Posted: Fri Mar 30, 2007 9:26 am |
| PCM programmer wrote: |
2. Do you have the contrast voltage set properly on the LCD ?
It should typically be somewhere in the range of 0 to .5 volts.
You have to set it with two resistors, or with a trimpot connected
between +5 and ground, with the center tap going to the LCD
contrast pin. |
What happens to the LCD, when V_contrast = Vcc = +5V?
(I'm struggling with the same symptoms as the original poster.)
EDIT: Solved the problem http://www.ccsinfo.com/forum/viewtopic.php?t=30353 at the end of the thread. |
Trent___ Guest
| Powertip PC200-ARS-ASO-A |
Posted: Wed Jun 20, 2007 8:17 am |
I am having the same trouble as the other posters.
Have anyone got the LCD mentioned in the subject to this post to work ?
I am using the FLEX_LCD driver, 4 bit mode and the display is correctly contrast.
The PIC is 18F2680
Is there any fine detail that I might have missed that anyone can offer ? |
