This is all CCS Wizard code. The setup_spi() statement shown
above in bold will shut down the SSP module. That includes
shutting down the hardware i2c. Delete that line.
Philosopher
Posted: Sun Jan 28, 2007 10:45 am
Ahh.. that's it!
Thank you PCM programmer!
domdom
Posted: Fri Feb 16, 2007 6:51 am
what type of LCD you are using? i am currently using LCD 2x16 connecting to ds1307.
can this code be used in my application?
based on the software given by philosopher, pin DB0-DB7 of LCD connecting to which I/O ports of PIC?
Philosopher
Posted: Fri Feb 16, 2007 12:13 pm
I'm using a 4x16 display with a KS0066 controller chip. I believe that chip is compatible with HD44780.
You could use this code but I would recomend you to use the CCS or some other complete driver for this display instead. This is just me messing around.
If you use this code you should connect DB0-DB7 to port D.
