Posted: Thu Jan 18, 2007 5:02 pm |
I assume you're talking about Mark's LCD driver in the Code Library:
http://www.ccsinfo.com/forum/viewtopic.php?t=20182
I don't have PCM vs. 4.009 to test. The closest I have is vs. 4.014.
I installed that version and compiled the test program shown below.
I programmed it into a 16F877 installed on a PicDem2-Plus board,
with the 4 MHz "can" type external oscillator. It ran OK. I didn't
get any extra characters on the LCD after sending it a "clear screen"
command (\f). I have the original PicDem2-Plus board, not the
latest type, which has a power on/off control connected to pin D7 on
the PIC. Mark's driver (as posted) was for the original PicDem2-Plus.
Try this program. If you still have the problem, it might be caused
by vs. 4.009 of the compiler.
#include <16F877.H>
#include <lcdd.c>
lcd_putc('\f');
lcd_putc("Hello World\n");
lcd_putc("This is Line two");
