Help With Struct/Union of Bits
PostPosted: Sat Nov 04, 2006 11:00 am     Reply with quote
struct bfield {
   int8 status_bat       : 1;   //unit has low battery
   int8 status_dead_bat  : 1;   //unit has dead battery, will be shutting down
   int8 status_tampered  : 1;   //unit has been tampered with
   int8 status_bad_comms : 1;   //some failed packets or bad acks
   int8 status_off_air   : 1;   //unit is not communicating
union t_status_byte {
   struct bfield bits;
   int8 b;
union t_status_byte   unit_status_byte;
union t_status_byte   unit_prev_status_byte;
You will have to initialise the values yourself in the code:
unit_status_byte.b=0b00000000;
unit_prev_status_byte.b=0b00000000;
Which accesses the bytes.
The bits are then accessible with:
unit_status_byte.bits.status_bat etc..
You can obviously typedef the final union declaration if required.
jecottrell
PostPosted: Sat Nov 04, 2006 11:43 am     Reply with quote
Thanks a bunch. It took me a few minutes to figure out what was happening and do a little reading.
It worked great the way you had it in your post. But when I modified the code to use TYPEDEF it spit out an error: 'Expecting a ('. Anu idea what I'm doing wrong?
struct bfield {
   int8 bat       : 1;   //unit has low battery
   int8 dead_bat  : 1;   //unit has dead battery, will be shutting down
   int8 tampered  : 1;   //unit has been tampered with
   int8 bad_comms : 1;   //some failed packets or bad acks
   int8 off_air   : 1;   //unit is not communicating
typedef union u_status_byte {
   struct bfield bit;
   int8 byt;
u_status_byte   unit_status;
u_status_byte   unit_prev_status;
Again, thanks for all your time,
John
PostPosted: Sat Nov 04, 2006 12:01 pm     Reply with quote
This is something I use for human input. A joystick with 4 momentary switches (north, south, east, west) and 3 buttons (top, bottom, trigger) as well as one more switch (compressor off) are connected to port C on a PIC. All of port C's lines are pulled high - closing a switch grounds the line.
union {
   int8 portc;
   struct {
      int1 s; // c0
      int1 n; // c1
      int1 e; // c2
      int1 w; // c3
      int1 trigger; // c4
      int1 bottom; // c5
      int1 top; // c6
      int1 comp_off; // c7
   } bits;
} input;
#byte portc = 0xf82
A timer interrupt set to go off every 13 ms (roughly) triggers a read of the entire port. That looks like this:
input.portc = portc;
I then check to see if the value I just read has changed from the last time I read it. Then to test if a particular line is down (active):
if (!input.bits.trigger) {
etc etc etc
jecottrell
PostPosted: Sat Nov 04, 2006 12:08 pm     Reply with quote
Newguy,
Thanks. I like that way also. But still, no one has come out and said in either solution whether, there is a guarantee that the bits will always be located in the same location in the byte in each declaration of the byte size variable. These bytes are going to be sent back and forth by radio, in a packet, and the receiving unit has to have each status bit in the same location.... Does that make sense? I'm not sure if I'm explaining it clearly enough?
Thanks.
John
struct bfield bits;
int8 b;
You don't need a union. You can zero the whole structure with one
line of code.
// Create two structures.
// Zero both structures.
unit_status_byte = 0;
unit_prev_status_byte = 0;
Here's the symbol table:
unit_status_byte        00000021
unit_prev_status_byte   00000022
Here's the .LST file:
0000            00326 .... unit_status_byte = 0;
0016 01A1       00327 CLRF   21
0000            00328 .... unit_prev_status_byte = 0;
0017 01A2       00329 CLRF   22
PostPosted: Sat Nov 04, 2006 12:18 pm     Reply with quote
Only CCS would know the answer for certain, because it depends upon
the internal compiler code. All that we could do, is to run a few tests
and then make an assessment based on that.
With regard to portability, I remembered that bitfields can't be
depended upon to be portable across machines. That's not really
your question, but it's still of interest. There are several comments
on this at the end of the bitfields section on this page:
http://icecube.wisc.edu/~dglo/c_class/odds_n_ends.html
jecottrell
PostPosted: Sat Nov 04, 2006 12:27 pm     Reply with quote
EDIT:
Just caught your second reply. I'll experiment and report back. Any idea on the error during compilation described above?
PCM,
Thanks for the reply. I think I may have confused the issue by assigning 0b00000000 to the variable in the declaration. I'm not having a problem doing that.
I've got a variety of sensors that are communicating with a hub. A number of statuses will be tracked and I thought I'd save room in my comm packet if I just packed them into a single byte. I can use the standard bit set/test/clear functions but I thought I'd try something a little more 'elegant'.... (complex). So I need to be able to send the byte back and forth by radio (standardized bit location required) and I'd like to be able to easily get at each of those status bits.
John
PostPosted: Sat Nov 04, 2006 12:42 pm     Reply with quote
You have to give the 'typedef' a name, as opposed to the 'union' a name.
When you define a union or structure, the layout is:
struct/union struct/union_name {
   declared stuff;
} variable/typedef_name;
So just move the name declaration from where I have it (to declare the union), to the end where you had it (for typedef).
Personally, I slightly prefer to 'know' that I am dealing with a structure or union, so name these, rather than hiding it behind a typedef, but this is purely a 'personal' thing. Smile
PostPosted: Sat Nov 04, 2006 12:46 pm     Reply with quote
Bitfields are meant to declare from LSB upwards, so, the bits will be in the order you expect. You can test this by just looking at the byte value, or the access code. For instance, the line:
unit_status_byte.bits.status_bat=1;
Codes as:
000A4: BSF 05.0
With the symbol table, showing:
005 unit_status_byte
So the behaviour is exactly as expected. Smile
jecottrell
PostPosted: Sat Nov 04, 2006 12:50 pm     Reply with quote
Got both replies. Thanks!
Your approach makes sense and will be helpful in six months when I have to make revisions.
John
