procedures
PostPosted: Tue Jul 25, 2006 2:19 pm     Reply with quote
Here is the 18F version, with a demo program that shows how to
call the functions.
#include <18F452.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
// do_pin_io() --
// This function will perform an i/o action on a CCS pin.
// The ccs_pin parameter must be a value defined in the .H
// file for your PIC, such as PIN_B0, PIN_C5, etc.
// The CCS pin value and state can be passed in variables.
// The action must be as follows:
// Action = 0:  Set the specified pin = 0
// Action = 1:  Set the specified pin = 1
// Action = 2:  Read the specified pin and return
//                   its value (0 or 1).
// Any action value > 2 will be treated as 2.  For actions
// 0 and 1, the return value has no meaning (but 0 is
// returned).
// This function only works for the 18F series PICs, in
// which the i/o ports are at addresses 0xF80 to 0xF84,
// and the corresponding TRIS registers are known to be
// at 0xF92 to 0xF96, respectively.
#define SET_LOW   0
#define SET_HIGH  1
#define READ_PIN  2
int8 do_pin_io(int16 ccs_pin, int8 action)
int16 io_port;
int16 io_tris;
int8 bitmask;
int8 retval;
int8 const bitmask_table[] =
   {0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
retval = 0;
io_port = ccs_pin >> 3;   // Get the i/o port address
bitmask = bitmask_table[ccs_pin & 7];   // get mask
io_tris = io_port + 0x12;  // Get TRIS register address
if(action < 2)  // Is this an output action ?
   *(io_tris) &= ~bitmask; // Set TRIS = output
   if(action)
      *io_port |= bitmask;    // Set pin = 1
      *io_port &= ~bitmask;   // Set pin = 0
else  // If not, we will read the pin  (action = 2)
   *io_tris |= bitmask;     // Set TRIS = input
   retval = !!(*io_port & bitmask);  // Read pin (ret. 0 or 1)
return(retval);   // This only has meaning if action = 2
int8 value_read;
// Blink an LED on pin B0.  Also read pin B1 and
// display the value read.
   do_pin_io(PIN_B0, SET_LOW);
   do_pin_io(PIN_B0, SET_HIGH);
   value_read = do_pin_io(PIN_B1, READ_PIN);
   printf("%u ", value_read);
