Re: Clearing RX buffer and TX Buffer |
Posted: Sun Feb 09, 2003 5:18 pm |
:=Hello,
:= my program works if I don't use a Hardware UART, but I need the Set_uart_speed() function. So isn't any way to "clear" the RX buffer, so before a getc() I clear the buffer and everything is okey. Isn't any bit in a register that do this?
I tried the SPEN and CREN bits, and they didn't work.
The method that does work, requires reading the RCREG three
times. See the following demo program. I think the
"clear_usart_receiver()" function will do what you want.
Try it.
Code: | #include "c:\program files\picc\devices\16F877.h"
#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT, NOLVP
#use Delay(clock=8000000)
#byte RCREG = 0x1A
void clear_usart_receiver(void);
main()
char c;
printf("Press 3 or more keys within 5 seconds.\n\r");
delay_ms(5000);
clear_usart_receiver();
if(kbhit() == 0)
printf("The receive buffer was cleared.\n\r");
printf("The receive buffer was not cleared.\n\r");
printf("It contains these chars: \n\r");
if(kbhit())
c = getc();
putc(c);
// Clear the USART receive register and its fifo
// by reading it three times.
char c;
c = RCREG;
c = RCREG;
c = RCREG;
Edited to put the program in a code block so it looks better.
Last edited by PCM programmer on Thu Sep 18, 2008 4:37 pm; edited 1 time in total |
Ezequiel Guest
Posted: Sun Feb 09, 2003 7:08 pm |
Two more things. First, why read it three times and not more or less. Second, why do you use the Error parameter in #use RS232.
I think I'll modify my circuit and use two buffers with Tri State, anyway-
Ezequiel
Original Post ID: 11463 |
Posted: Sun Feb 09, 2003 7:50 pm |
:=Hello,
:= Two more things. First, why read it three times and not more or less. Second, why do you use the Error parameter in #use RS232.
Look at Figure 10-4 in the 16F877 data sheet. This is a
block diagram of the USART receiver. It consists of the
RSR register, and the RCREG register. The RCREG register
is a "2-deep" fifo. So, you could have 2 chars in the
RCREG fifo, and have another char being shifted into the
RSR register. That's a total of 3 chars. So that's why
you need to read the receiver 3 times to make sure you clear it.
The ERRORS parameter is used to clear any overrun or framing
errors that may occur. It's rare to get such an error, if
your baud rate is correct, and if you read the chars from
the receiver quickly enough. But if you do get an error,
it can lock the receiver, and your program will lock up.
By using the ERRORS parameter, you cause the compiler to
put in code that checks for these conditions and then clears
the error if it occurs. It's a safety measure.
Original Post ID: 11464 |
