Posted: Thu Sep 25, 2014 12:20 pm |
Here is the ported code from the links I posted. This code does not use
the internal DMP mpu6050 to do the calculations. The calculations are
done in the PIC with the following code.
Here's the sample output I got. As I lift up one side of the mpu6050
board, the Y angle increases:
| Quote: |
Gyro X offset sum: -234453 Gyro X offset: -234
Gyro Y offset sum: 138770 Gyro Y offset: 138
Gyro Z offset sum: -78797 Gyro Z offset: -78
accel_xangle = 0
accel_yangle = 3
accel_xangle = 0
accel_yangle = 3
accel_xangle = 0
accel_yangle = 3
accel_xangle = 0
accel_yangle = 3
accel_xangle = 0
accel_yangle = 16
accel_xangle = 0
accel_yangle = 36
accel_xangle = 0
accel_yangle = 84
Test program:
| Code: | #include <18F4620.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOLVP
#use delay(internal=32M)
// I'm using software i2c on these pins for the mpu6050
// because the hardware pins on C3 and C4 are already
// in use on my development board.
#use i2c(Master, scl=PIN_C0, sda=PIN_C1)
#include <math.h>
#define MPU6050_SLAVE_WRT 0xD0
#define MPU6050_SLAVE_RD 0xD1
// Register addresses
#define MPU6050_WHO_AM_I 0x05
#define MPU6050_SMPLRT_DIV 0x19
#define MPU6050_CONFIG 0x1A
#define MPU6050_GYRO_CONFIG 0x1B
#define MPU6050_PWR_MGMT_1 0x6B
#define ACCEL_XOUT_H 0x3B
#define ACCEL_XOUT_L 0x3C
#define ACCEL_YOUT_H 0x3D
#define ACCEL_YOUT_L 0x3E
#define ACCEL_ZOUT_H 0x3F
#define ACCEL_ZOUT_L 0x40
#define GYRO_XOUT_H 0x43
#define GYRO_XOUT_L 0x44
#define GYRO_YOUT_H 0x45
#define GYRO_YOUT_L 0x46
#define GYRO_ZOUT_H 0x47
#define GYRO_ZOUT_L 0x48
// In the +/- 500 degrees mode, the gyro sensitivity is 65.5 LSB/dps.
#define gyro_xsensitivity 66.5 //66.5 Dead on at last check
#define gyro_ysensitivity 66.5 //72.7 Dead on at last check
#define gyro_zsensitivity 65.5
#define a 0.01
#define dt 0.0025
// Global variables
float gyro_xrate;
float gyro_yrate;
float gyro_zrate;
//int16 gyro_xrateraw;
//int16 gyro_yrateraw;
//int16 gyro_zrateraw;
signed int16 gyro_xout;
signed int16 gyro_yout;
signed int16 gyro_zout;
signed int16 accel_xout;
signed int16 accel_yout;
signed int16 accel_zout;
signed int16 gyro_xout_offset;
signed int16 gyro_yout_offset;
signed int16 gyro_zout_offset;
signed int32 gyro_xout_offset_1000sum;
signed int32 gyro_yout_offset_1000sum;
signed int32 gyro_zout_offset_1000sum;
float gyro_xangle;
float gyro_yangle;
float gyro_zangle;
//int32 gyro_xangleraw;
//int32 gyro_yangleraw;
//int32 gyro_zangleraw;
float accel_xangle;
float accel_yangle;
//float accel_zangle;
//float kalman_xangle;
//float kalman_yangle;
//float kalman_zangle;
int16 MPU6050_read_word(int8 reg_addr)
int8 lsb, msb;
int16 retval;
i2c_start();
i2c_write(MPU6050_SLAVE_WRT);
i2c_write(reg_addr);
i2c_start();
i2c_write(MPU6050_SLAVE_RD);
msb = i2c_read(); // Read MSB byte first.
lsb = i2c_read(0); // Do a NACK on the last read
i2c_stop();
retval = make16(msb, lsb);
return(retval);
void Get_Accel_Values()
accel_xout = MPU6050_read_word(ACCEL_XOUT_H);
accel_yout = MPU6050_read_word(ACCEL_YOUT_H);
accel_zout = MPU6050_read_word(ACCEL_ZOUT_H);
void Get_Gyro_Rates()
gyro_xout = MPU6050_read_word(GYRO_XOUT_H) - gyro_xout_offset;
gyro_yout = MPU6050_read_word(GYRO_YOUT_H) - gyro_yout_offset;
gyro_zout = MPU6050_read_word(GYRO_ZOUT_H) - gyro_zout_offset;
gyro_xrate = (float)gyro_xout/gyro_xsensitivity;
gyro_yrate = (float)gyro_yout/gyro_ysensitivity;
gyro_zrate = (float)gyro_zout/gyro_zsensitivity;
gyro_xangle += gyro_xrate * dt;
gyro_yangle += gyro_yrate * dt;
gyro_zangle += gyro_zrate * dt;
void Get_Accel_Angles()
accel_xangle = 57.295*atan((float)accel_yout/ sqrt(pow((float)accel_zout,2)+pow((float)accel_xout,2)));
accel_yangle = 57.295*atan((float)-accel_xout/ sqrt(pow((float)accel_zout,2)+pow((float)accel_yout,2)));
void Calibrate_Gyros()
int16 x = 0;
gyro_xout_offset_1000sum = 0;
gyro_yout_offset_1000sum = 0;
gyro_zout_offset_1000sum = 0;
for(x=0; x<1000; x++)
gyro_xout = MPU6050_read_word(GYRO_XOUT_H);
gyro_yout = MPU6050_read_word(GYRO_YOUT_H);
gyro_zout = MPU6050_read_word(GYRO_ZOUT_H);
gyro_xout_offset_1000sum += gyro_xout;
gyro_yout_offset_1000sum += gyro_yout;
gyro_zout_offset_1000sum += gyro_zout;
delay_ms(1);
gyro_xout_offset = gyro_xout_offset_1000sum/1000;
gyro_yout_offset = gyro_yout_offset_1000sum/1000;
gyro_zout_offset = gyro_zout_offset_1000sum/1000;
printf("Gyro X offset sum: %ld Gyro X offset: %ld \n\r", gyro_xout_offset_1000sum, gyro_xout_offset);
printf("Gyro Y offset sum: %ld Gyro Y offset: %ld \n\r", gyro_yout_offset_1000sum, gyro_yout_offset);
printf("Gyro Z offset sum: %ld Gyro Z offset: %ld \n\r", gyro_zout_offset_1000sum, gyro_zout_offset);
#define BW_256_HZ 0
#define BW_10_HZ 5
#define BW_5_HZ 6
void set_DLPF(int8 bandwidth)
i2c_start();
i2c_write(MPU6050_CONFIG);
i2c_write(bandwidth);
i2c_stop();
void Setup_mpu6050(void)
i2c_start();
i2c_write(MPU6050_PWR_MGMT_1);
i2c_write(0x00);
i2c_stop();
i2c_start();
i2c_write(MPU6050_GYRO_CONFIG);
i2c_write(0x08);
i2c_stop();
i2c_start();
i2c_write(MPU6050_SMPLRT_DIV);
i2c_write(0x07);
i2c_stop();
delay_ms(100); // Gyro start-up time is 30ms after power-up.
Setup_mpu6050();
Calibrate_Gyros();
//set_DLPF(BW_5_HZ);
Get_Accel_Values();
Get_Gyro_Rates();
Get_Accel_Angles();
printf("accel_xangle = %7.0f \n\r", accel_xangle);
printf("accel_yangle = %7.0f \n\r", accel_yangle);
printf("\n\r");
delay_ms(2000);
This code is not mine. I just ported it to CCS. I don't want to trouble-
shoot the code. I don't want to explain it. I just wanted to get you going
on your project. |
Ruby
Posted: Thu Sep 25, 2014 12:44 pm |
| Thank you. I will check the code. Thanks alot. |
Ruby
Posted: Fri Sep 26, 2014 3:55 pm |
| Hi guys. Code works perfect with 16f877a. I have also cleaned the code cause it uses only accel values. I am trying to find some examples about DMP. |
mohammad3d
