Posted: Tue Aug 12, 2014 11:00 am |
You're trying to create your own test program. I read some previous posts
where forum members say it does work. It occurred to me that they were
likely using the Ex_fat.c example to control the fat commands. So I did
that. It works.
I test this with compiler vs. 5.026. I did a clean install of the compiler.
The files don't have any of andrewg's fixes, or any changes.
First I edited Ex_fat.c to match my board, as shown below:
#include <18F4620.h>
//#include <18F67J60.h> // *** Commented out
#device PASS_STRINGS = IN_RAM
#fuses NOWDT, HS, NOPROTECT
#use delay(clock=20M) // *** Was 25 MHz
Actually, before that, I checked my hardware by running Brush Electronic's
SD Utils program. It said the SD card was activated OK. So I'm pretty
sure my hardware is working. I'm using a PNY brand, 2 GB SD card.
It's not an SDHC card.
I started TeraTerm and ran the Ex_fat program. The Ex_fat.c file has
a list of commands near the start of the file.
1. First I did a "makefile test.txt" command but it froze. It didn't display
a result code. So then I reset and re-started the Ex_fat program.
2. Then I did a Dir command (as shown below). It showed no files.
3. Then I decided it would be a good idea to format the card.
2 GB is 2097152 KB. So I used that as a parameter. It said OK.
4. Then I made test.txt and it said OK.
5. Then I did a Dir and it showed test.txt was there.
/> dir
/> format 2097152
Formatting media (size=2097152): OK
/> make test.txt
Making file '/test.txt': OK
/> dir
test.txt
electr0dave
Posted: Tue Aug 12, 2014 12:04 pm |
Oh God ...
I will test the sample program again .... but I still do not understand the reason for all this mess ...
You have pull-up in SD_DO?
I will do everything as you say!
I'm currently making a new installation of my version of CCS (5.025). |
Posted: Tue Aug 12, 2014 2:16 pm |
As a comment, one thing that might apply, is lack of good smoothing. The SD card draws significant current spikes, and required good smoothing close to it. This is the sort of thing that PCM_programmer would do 'automatically'....
On the pull-ups, it is worth quoting from the SD card spec's:
"All hosts shall provide pull-up resistors on all data lines DAT[3:0] as described in section 6 of the SD Physical Specification Version 1.01."
D3, can be 'got away with', since this has an internal 50K resistor in the card, that is enabled by default. The 'shall' says it all.
The point is that any line set as an input, can float into the 'transition' area, and this results in high consumption, and erratic behaviour... |
electr0dave
Posted: Tue Aug 12, 2014 2:21 pm |
In fact it works like you said ....
But I tried to do something else .... I did reset the circuit and "dir" again so I can see if the file was still there.
The answer is no :(.
image hosting sites |
Posted: Tue Aug 12, 2014 2:23 pm |
I'm at a different location for most of today. I'm not at hardware bench.
I can't work on it now. Maybe someone else can help. |
electr0dave
Posted: Tue Aug 12, 2014 2:41 pm |
OK, I added something written to the file and apparently works even after reset.
PCM programmer your help was invaluable!
Obviously, I also thank all those who came here to answer!
I will continue to put here some questions that may arise, but now finally I have something to "work".
Posted: Tue Aug 12, 2014 3:22 pm |
Now, for the 'fixes'.
There are two sets. The generic ones linked to (which are worth doing), and the ones for MBR support:
<http://www.ccsinfo.com/forum/viewtopic.php?t=43402&highlight=mbr>
This fix would remove the need to reformat the card.
There are to fundamentally different ways of laying out the data on the card. The first is the 'floppy' layout, and the second the 'hd' layout. The CCS drivers as standard only support the former. This fix adds support for the latter. |
electr0dave
Posted: Wed Aug 13, 2014 7:03 am |
I'm making some changes.
1st - fat.c file in line 221
| Code: | #define FAT16
// # define FAT32 |
2nd - gives error while compiling
3rd - change line 1342 to
| Code: | | if (write_fat (Next_Free_Clust, 0xFFFF) == EOF) |
In this case, EOF is returned, giving error to initialize FAT, when the card is not inserted.
Without the card inserted:
free screen capture
I know that the next change can not be "the right one", but it seems to work ...
1 - I put in line 2601:
| Code: | ec += mmcsd_init();
if(ec != GOODEC)
return EOF; |
2 - below the last "# endif" I commented:
| Code: | //if(ec != GOODEC)
// return EOF; |
The image below shows two tests: the first without the card (error message) and the second with the card (showing the prompt).
images upload |
