nRF24L01+ full driver by Eduardo Guilherme Brandt
Goto page Previous  1, 2, 3 ... 17, 18, 19, 20  Next
sebcar
Problem with PIC16LF88
PostPosted: Wed May 03, 2017 5:35 am     Reply with quote
Dear Eduardo,
First, thank you for driver. However, it has been a long time since i have programed on PIC, and i did not manage to compile.
First I give my scheme:
[img]https://goo.gl/photos/4XMjeoEfiauCHvBMA[/img]
I use a PIC 16LF88, the internal oscillator at 4 MHz, ICSP and 3.3V PIC.
I program on CCS v 5.008.
Secondly I have this code:
.h File
#include <16F88.h>
#DEVICE *=16    ICD=TRUE  PASS_STRINGS=IN_RAM
#device ADC=10
#FUSES PUT                      //Power Up Timer
#use delay(internal=4MHz)
#use STANDARD_IO( A )
#use FIXED_IO( A_outputs=PIN_A2,PIN_A1 )
The .c file:
#include <Domotique Pic.h>
//#USE SPI (MASTER, SPI1, ENABLE=PIN_B3, MODE=0, BITS=8, STREAM=RF24_SPI)
//#USE SPI(FORCE_SW , DI=PIN_B1, DO=PIN_B2, CLK=PIN_B4,ENABLE=PIN_B3, MASTER, MODE=0, BITS=8, MSB_FIRST, STREAM=STREAM_SPI)
#USE SPI(FORCE_SW, SPI2, MASTER, BAUD=1000000, MODE=0, BITS=8, MSB_FIRST, STREAM=STREAM_SPI2)
#define BatMes    PIN_A0
#define DhCt      PIN_A1
#define BatCt     PIN_A2
#define DHT-11    PIN_A4
#define SPI_MISO  PIN_B1
#define SPI_MOSI  PIN_B2
#define RF24_CS   PIN_B3
#define SPI_CLK   PIN_B4
#define RF24_CE   PIN_B5
#define RF24_IRQ  PIN_B0
#define  RF24_PERFORMANCE_MODE   //performance mode ON
#define PGC   PIN_B6
#define PGD   PIN_B7
#define RF24_SPI STREAM_SPI2
#include <nRF24L01P.c>
   setup_adc_ports(sAN0);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);      //2,0 s overflow
      output_high(PIN_A7);
      output_low(PIN_A7);
      RF24_driver_use_example_TXdata_simple();
My problem is that I have to make modification into driver to compile.
I changed the code on:
int RF24_comm(int comm, int32 comm1, int commDS) {
  //commDS=datasize(1 to 32 bits)
   int rv; //rv=return value(SPI nRF24 status read value)
   RF24_select();
   RF24_xfer(comm);    //RF24 Write address/command (see RF24_addr addresses list tabble in .h file)
   rv=spi_xfer(RF24_SPI, comm1); //Write config.value or command (1 to 32 bits of data)___I CANNOT USE RF24_xfer() ALIAS BECAUSE IT NOT ACCEPTS MORE THAN 1 PARAMETER rv=spi_xfer(RF24_SPI, comm1, commDS);
   rv=spi_read2();    //It's necessary due to spi_xfer read bug
   RF24_unselect();
   return rv;
I have to suppress commDS from spi_xfer to not have the error:
"Expression must evaluate a constant".
Second error:
In nrf24l01p.h i modify:
//Automated functions contemplated register.
enum RF24_STATUS {   // **Status Register (In parallel to the SPI command word applied on the MOSI pin, the STATUS register is shifted serially out on the MISO pin)
   IRQ_RX_dataready  =0b01000000,   // (0)Data Ready RX FIFO interrupt. Asserted when new data arrives RX FIFOc.Write 1 to clear bit.
   IRQ_TX_datasent   =0b00100000,   // (0)Data Sent TX FIFO interrupt. Asserted when packet transmitted on TX. If AUTO_ACK is activated,this bit is set high only when ACK isreceived.Write 1 to clear bit.
   IRQ_MAX_retransmit=0b00010000,   // (0)Maximum number of TX retransmits interrupt Write 1 to clear bit. If asserted it must be cleared to enable further communication.
   IRQ_ALL           =0b01110000,   // Allows clearing all IRQs at the same time
   RX_PIPE0          =0b00000000,   // (R)(bits 3:1)Data pipe number for the payload available for reading from RX_FIFO 000-101: Data Pipe Number
   RX_PIPE1          =0b00000010,   // (R)(bits 3:1)Data pipe number for the payload available for reading from RX_FIFO 000-101: Data Pipe Number
   RX_PIPE2          =0b00000100,   // (R)(bits 3:1)Data pipe number for the payload available for reading from RX_FIFO 000-101: Data Pipe Number
   RX_PIPE3          =0b00000110,   // (R)(bits 3:1)Data pipe number for the payload available for reading from RX_FIFO 000-101: Data Pipe Number
   RX_PIPE4          =0b00001000,   // (R)(bits 3:1)Data pipe number for the payload available for reading from RX_FIFO 000-101: Data Pipe Number
   RX_PIPE5          =0b00001010,   // (R)(bits 3:1)Data pipe number for the payload available for reading from RX_FIFO 000-101: Data Pipe Number
   RX_BUFFER_EMPTY   =0b00001110,   // (R)Data pipe number for the payload available for reading from RX_FIFO 000-101: Data Pipe Number
   TX_BUFFER_FULL2    =0b00000001    // (R)(0)TX FIFO full flag. 1: TX FIFO full. 0: Available locations in TX FIFO.
I have to change TX_BUFFER_FULL to TX_BUFFER_FULL2 to not have the error:
"Identifier is already used in this scope".
Are there some more errors to correct to be able to communicate as soon as possible ? I want to communicate with a Raspberry.
Thank you a lot.
Sebastien, Pic Dummy.
PostPosted: Wed May 03, 2017 5:57 pm     Reply with quote
That's because in modern versions of the CCS compiler, if you specify
hardware spi in the #use spi() statement, then CCS will only allow a
constant numeric value for the "number of bits" parameter in spi_xfer().
In other words, it gives an error for this:
But it will compile with this:
rv=spi_xfer(RF24_SPI, comm1, 8);
But you don't have to worry about it. You can comment out the last
RF24_comm() function in that section of code. The last section is not used.
Comment it out, as shown below. Then it's no problem:
int RF24_comm(int comm, int32 comm1, int32 commDS) {   //commDS=datasize(1 to 32 bits)
   RF24_select();
   RF24_xfer(comm);                    //RF24 Write address/command(see RF24_addr addresses list tabble in .h file)
   rv=spi_xfer(RF24_SPI, comm1, commDS); //Write config.value or command(1 to 32 bits of data)___I CANNOT USE RF24_xfer() ALIAS BECAUSE IT NOT ACCEPTS MORE THAN 1 PARAMETER
//   rv=spi_read();                     //It´s necessary due to spi_xfer read bug
   RF24_unselect();
   return rv;                    //Return last read value
There are several problems in your #use spi() statement above:
1. There is no "SPI2" module in the 16LF88. That PIC only has SPI1.
2. It's better to use hardware SPI, because it's faster.
3. I see no need to rename the stream.
I changed it to this:
#USE SPI(MASTER, SPI1, BAUD=1000000, MODE=0, BITS=8, MSB_FIRST, STREAM=RF24_SPI)
// #define RF24_SPI STREAM_SPI2   // Comment out, or delete this line.
Then it should compile, though it will still give some warnings.
Eduardo__
Re: Problem with PIC16LF88
PostPosted: Wed May 03, 2017 7:10 pm     Reply with quote
About the error "Expression must evaluate to a constante", probably you did not used the expression at the beginning of the program
#device PASS_STRINGS=IN_RAM
See later posts,.. someone have had the same problems than you and it was solved.
sebcar wrote:
Dear Eduardo,
.h File
#include <16F88.h>
#device ADC=10
The .c file:
#define DhCt      PIN_A1
#define PGC   PIN_B6
#define PGD   PIN_B7
      output_low(PIN_A7);
   RF24_select();
   RF24_unselect();
   return rv;
Second error:
Thank you a lot.
PostPosted: Wed May 03, 2017 8:03 pm     Reply with quote
He has PASS_STRINGS=IN_RAM in his code. It's in the 2nd line of the .h file.
I really think the problem is as I described in my post.
sebcar
PostPosted: Thu May 04, 2017 1:50 am     Reply with quote
Yes, i agree with PCM programmer.
sebcar
PostPosted: Thu May 04, 2017 5:41 am     Reply with quote
It compiles now perfectly.
Nevertheless, each time i try to launch the code with a function of the library, it bugs and do not execute even function prior to the library one.
An idea
sebcar
PostPosted: Thu May 04, 2017 6:20 am     Reply with quote
I found that my module is a fake nrf24l01. I wait for a true one and post a reply.
sebcar
PostPosted: Wed May 10, 2017 7:25 am     Reply with quote
It seems always blocked with not naked module.
I read that some person have problem with interrupt pin blocked to one and stopping the program.
Is it solved or not ?
I try to remove pull-up.
sebcar
PostPosted: Wed May 10, 2017 8:13 am     Reply with quote
It seems that spi never try to communicate
sebcar
PostPosted: Wed May 10, 2017 8:49 am     Reply with quote
I try with CCS 4.
It seems to communicate now but still blocked
sebcar
PostPosted: Thu May 11, 2017 9:51 am     Reply with quote
Avec mon 16F, j'ai l'impression que l'INT ne repasse jamais à 0.
J'ai testé avec un 18F et là cela fonctionne.
Une idée?
Translation:
With my 16F, I feel that the INT never returns to 0.
I tested with an 18F and there it works.
An idea?
PannetierJ
Error at the compilation
PostPosted: Sun Jun 18, 2017 11:19 am     Reply with quote
Hello ,
I tried to use your library.
In the first time, I'm using Pcw 4.068
I commented this
// #include <spi_dma_PIC18F24J11.c> //PIC18F24J11 DMA driver(I have another topic with this driver. It´s not essential)
Now I have few error on the warning
-> Invalid Pre-Processor directive
Best regard
PannetierJ
PostPosted: Sun Jun 18, 2017 2:23 pm     Reply with quote
It's Ok .
I change my version of compiler.
Now it's Ok
Nevertheless, I have a second problem
Undefined STREAM_SPI2
Undefined --DMA_read
Undefined --DMA_start
Undefined -- DMA_is_busy
PostPosted: Mon Jun 19, 2017 10:02 am     Reply with quote
I'm trying to put bugs into my test program to re-create what you're doing.
So, I added this line at the top of the nRF24L01P.c file:
#define RF24_USE_DMA
That caused me to get all these error messages:
*** Error 12 "C:\Program Files\PICC\...\nRF24L01P.c" Line 161(15,16): Undefined identifier -- DMA_read
*** Error 12 "C:\Program Files\PICC\...\nRF24L01P.c" Line 162(16,17): Undefined identifier -- DMA_start
*** Error 12 "C:\Program Files\PICC\...\nRF24L01P.c" Line 163(24,25): Undefined identifier -- DMA_is_busy
*** Error 12 "C:\Program Files\PICC\...\nRF24L01P.c" Line 180(16,17): Undefined identifier -- DMA_write
*** Error 12 "C:\Program Files\PICC\...\nRF24L01P.c" Line 181(16,17): Undefined identifier -- DMA_start
*** Error 12 "C:\Program Files\PICC\...\nRF24L01P.c" Line 182(24,25): Undefined identifier -- DMA_is_busy
*** Error 12 "C:\Program Files\PICC\...\nRF24L01P.c" Line 334(25,26): Undefined identifier -- DMA_default_config
So remove this line. Get rid of it:
Look at the end of this post. I explain how to fix that error message:
http://www.ccsinfo.com/forum/viewtopic.php?t=47351&start=269
PannetierJ
PostPosted: Tue Jun 20, 2017 12:27 am     Reply with quote
Now it's ok.
I can compile my program, without error.
I remove #define RF24_USE_DMA
Thank you
Page 18 of 20
